I’ve been trying to follow this guide Volumio with 3.5" TFT Touch Screen (GPIO) RPi 3B+
but I cant seem to get my LCD screen to show anything but a white image. is there any troubleshooting I can do? any help is appreciated!
Please post the brand and exact model name of your display.
Unfortunately I think it’s a random no name from Ali express, I got it from a relative and didn’t buy it myself.
Could you post pictures of both sides of the display’s board?
I suggest to start with a fresh Volumio installation and then proceed as follows:
Install the Touch Display plugin.
Execute
sudo apt-get -y install xserver-xorg-video-fbturbosudo apt-get -y install xserver-xorg-input-evdevsudo cp /usr/share/X11/xorg.conf.d/10-evdev.conf /usr/share/X11/xorg.conf.d/45-evdev.confsudo curl -L https://github.com/goodtft/LCD-show/raw/master/usr/tft35a-overlay.dtb -o /boot/overlays/tft35a.dtbosudo curl -L https://raw.githubusercontent.com/goodtft/LCD-show/master/usr/99-calibration.conf-35-90 -o /etc/X11/xorg.conf.d/99-calibration.confsudo curl -L https://raw.githubusercontent.com/goodtft/LCD-show/master/usr/99-fbturbo.conf -o /usr/share/X11/xorg.conf.d/99-fbturbo.confcat >> /boot/userconfig.txt <<EOL dtparam=spi=on dtoverlay=tft35a EOL -
Reboot.
It worked, thanks a ton! Would it also be possible to connect the pi using a wifi dongle?
In principle, yes; however, I can’t say which adapters will work. You will find some threads on this topic using forum search, e.g. this one. To get more attention to your question, I suggest posting there or creating a new thread with an appropriate title.
Alright thanks, was planning on using an esp01s but I’ll create a different topic. On topic, is there a way to rotate the screen? Using the plugin dosent seem to work. Also is there some sort of calibration I can run for the touchscreen? Dosent really seem to work.
Yes, by how many degrees (clockwise) do you want to rotate the display - 90, 180 or 270 degrees?
