So how do i access the logs or what i mean is if i use SSH on my laptop make it much easy to work. So first it ask me to login and then do i type in /dev or livelog
now that i have the player up and running on my pi 4 how do i get a remote running on it. I bought the two Apple remotes that it has list in the plugins but as i tried both remotes. A1156 and A2195 they still donât work. i saved and rebooted the player.
I have two Apple remotes A1156 and A1294 like it shows in the âIR Remote Controller.â that shows the remotes in settings here
I tried each of the Apple remotes and save/ rebooted and nothing happen.
So how do i get to the IR remote Configurations to get the remote going on the player.
So all i need to do is in the plugin, select JustBoom that i got, set the GPIO configurations to GPIO 24. Then do i just connect the jumper wire from the Single out/Ground/ power from the IR sensor to the ground 3.3vol GPIO 24 and reboot.
If not already done: Make sure before choosing GPIO 24 that it is not already used elsewhere, e.g. by a DAC.
Also note that the GPIO number is not the number of the physical pin to which the infrared receiver is connected, but the Broadcom pin number (BCM), cf. GPIO 24 at Raspberry Pi GPIO Pinout.
