I am completely new to programming, I know nothing, I trusted a tutorial, but I can’t get the touch of the display connected in HDMI to work, I inserted these lines in the config:
hdmi_group=2
hdmi_mode=87
display_rotate=1
and the display works, I installed the TouchScreen plugin, I activated it, but it DOESN’T work, to be able to control Volumio I have to use the PC or the Smartphone.
Can you help me, Thanks Andrea
Sorry for my bad English
NB: Display LUCKFOX 7.9-inch HDMI Touchscreen LCD Display, 400*1280
Raspberry Pi 3 Model B+
DAC : Hifibox dac
Volumio Version : 3.785-2024-12-16
Editing “/boot/config.txt” is not recommended as modifications will be overwritten on Volumio updates. Instead use “/boot/userconfig.txt” as proposed by @Wheaten.
