no entries in the userconfig
Does it help to add
max_framebuffer_width=2560
max_framebuffer_height=720
back to â/boot/userconfig.txtâ?
Iâll try that later, thanks
This is the result after the entry
I also added:
disable_overscan=1
max_framebuffer_height=1080
The effect of the different settings regarding âmax_framebuffer_heightâ and âframebuffer_heightâ is hard to judge because all three pictures (including the one from post #19) show different display content. Is there an effect at all and if so what appears to be the best result so far?
BTW: Did you already try the suggestions from post #18?
yes, sorry, the image content should always be the same.
This is the best result in terms of aspect ratio, but not filling
Aspect ratio looks good, IMHO. Which settings are used to achieve this result?
hdmi_cvt=2560 720 60
hdmi_group=2
hdmi_mode=87
Did you test combining this with the framebuffer height and width settings?
Thanks, perfect.
I hadnât tested that yet.
Thanks for your patience and help!! ![]()
Now I just need a suitable skin for peppymeter
Would you mind posting your final display settings as a reference for future readers?
of course!
https://de.aliexpress.com/i/1005005826118725.html?gatewayAdapt=glo2deu
Resolution: 2560x720
Size outside: 366 Ă 115 Ă 11 mm (hĂvĂd)
Display area: 354.82 Ă 99,97 mm (h Ă v)
Connected via: HDMI
Touch: YES / USB-C
Power: USB-C 5V
Port: 1x HDMI mini, 2x USB-C
userconfig.txt:
#userconfig.txt:
# Touch Display 14.5 Zoll 2560x720
hdmi_group=2
hdmi_mode=87
Looks very nice!
Did you collect and write down all settings you did in the last years?
Might be an idea to collect them in a single topic.
Working LCD screens
Brand: Waveshare
Link: https://www.waveshare.com/7.9inch-hdmi-lcd.htm
Resolution: 400Ă1280
Connected via: HDMI
Touch: YES
userconfig.txt:
hdmi_group=2
hdmi_mode=87
display_rotate=3
hdmi_blanking=1
Remark:
No, not in particular for brand and model. Depending on the display in question I use only the more or less generalized instructions which I am posting from time to time.
Thank you for the information and it worked for my RB4B but NOT for my RB5 which only shows a stretched out display, I am using the same display 2560x720 that worked with the RB4. Iâve gone so far as to use the same SDcard from the RB4 in the RB5 and that didnât fix the stretched screen either,
Any suggestions? Thank you!
where did you get the black faceplate? love it all!
Rue - love to know where you got that case - itâs amazing!
I designed the housing with CAD QCAD and manufactured the parts with a CNC laser
