I have a problem in camillaDSP gui, when I try to mark the config file as active, the A icon is in the “shadow” and appear this message is : “check the backend configuration”
My log file is the following:
ERROR [src/bin.rs:344] Playback error: ALSA function ‘snd_pcm_open’ failed with error ‘ENOENT: No such file or directory’
ERROR [src/processing.rs:50] Message channel error: receiving on a closed channel
Hello Simone_Fusion, just a quick comment that my experience is exactly the same as yours: DSP plugin 1.49 works fine (and has for many months) but after the upgrade to 1.51 my Pi3 streamer basically refuses to function: hangs, stuttering, and total silence from any of the streamed sources. Downgrading to 1.49 restored volumio health. I have been using the same power supply for years.
I had similar problems with the primo I, the latest update of volumio, latest update FusionDSP and Roon bridge. (See post in ‘Volumio with Roon’)
The primo I was no longer recognized in Roon. After a reset to factory settings and installation of FusionDSP version 1.0.49, Roon recognizes the primo I and it works correctly again.
I get the same error message when trying to make a filter active.
“Mark this filter as active
Disabled since the backend is not able to store the active config file
Check the backend configuration”
Hi balbuze
I am reporting a problem (maybe integration) with FusionDSP and Volumio.
I am using 3.569 Volumio and 1.0.51 FusionDSP
Since a few days I am using a “Hifime S2 digi” toslink-usb converter which is correctly detected by Volumio . The converter can manage upto 192k but with a windows PC I set the internal sample rate to 44100/16 as the incoming digital signal from a cd player. Volumio is then connected to my usb DAC.
When I select the digital converter in Volumio as source to play the resulting sound is distorted . After some investigation, I found in Camilla GUI that the capturing rate is continuosly between 44100 and 48000 .
Any idea on how to fix it ? Thanks for your great work and support
Hello! I don’t know why under the latest Volumio3, if I turn on the FUSIONDSP plugin, the sound stutters and crackles. It’s like downloading the RPI4B 8gb card. (I disabled all other plugins). Anyway, Volumio3 is not stable in itself, I encounter many small annoying errors. But FUSIONDSP shouldn’t crack… Thanks.
