FusionDsp : the complete Dsp center for Volumio3!
Please test the same with FusionDSP disabled.
Are you sure you installed V1.036 and not V1.035?
As what you just described was an bug in V1.035.
Please give the output of the command:
cat data/plugins/audio_interface/fusiondsp/asound/volumioDsp.postDsp.10.conf
For info, a problem may be due to an error in a config file. This is the case in FusionDsp
v1.0.33
v1.0.34
v1.0.35
So update to v1.0.36.
It should fix this.
Could housecurve app somehow have interfered with it? it worked the first time and now I’m getting interference and can’t upload?
Just managed to get round to installing 1.0.36
Had a good mess about trying to break it, but so far all seems good.
Btw all day with dsp on it’s worked well
Here as well, 20hr test playlist with a mix of formats, bit and samplerates.
No issue at all on an Odroid N2+, which had problems with earlier versions (white noise, completely frozen etc.).
Thank you for your feedbacks.
Glad to read this!
Enjoy :slightly_smiling_face:
What is the problem?
Can you post the file you try to import from HousCurve to FusionDsp?
And log please.
the first time I did it , it worked fine. THe tone sounded well and picked up by phone well and uploaded it . The changes made to the dsp were great . From then on the tone is garbled at parts . Usually at the beginning and uploading doesn’t work.
Not sure I know how to upload houscurve file.
FusionDsp v1.0.37 beta
  • LowshelfFO and HighshelfFO for PEQ
  • NEW super simple 3 bands graphic EQ! Simple to use but technically advanced with a Lowshelf, a peaking and a highshelf as filters.
This is a beta though. You have to remove previous, reboot and install…
Enjoy :wink: and feedback!
FusionDsp v1.0.39 stable. This is a HOT fix for v1.0.38 when New eq 3 bands was not available after update :wink:
Warning : Reboot after update. Enjoy :wink:
@balbuze
Found another way FusionDSP goes silent. It has quite a specific use case, but did happen a few times the other night during a 3 hour period.
Situation…There was two of us choosing tracks (from either the queue or from my local library on my server).
I’d pick a track, it’d play and as it faded out the next track was selected by the missus, back and forth.
But… occasionally everything would go silent, and unresponsive. At the time, I just rebooted and off it went again, until it happened again…
Yesterday I had a few hours to mess about and try to reproduce it.
It is very specific to reproduce, if I select the next track ~1 second before the end of the last track then it’ll go silent and play / pause and track selection is unresponsive.
A reboot will fix it, if I go into plugins, disable and enable FusionDSP it will start playing again.
Also not sure if it did it more going from 16b to 24b, but that may be a coincidence.
Did wonder if it was a Volumio issue but I cannot reproduce it with FusionDSP disabled.
I know… if we use the ā€œadd to queueā€ option it wouldnt happen. On a mobile device ā€œadd to queueā€ is hit and miss, add a late night and a few rums into that and you have no chance :smiley:
I just wish that the Volumio team would add the option to be able to select the track which then adds it to the queue.
but hey ho it is what it is
CammillaDSP Logs from the reproduced efforts yesterday log 1… log 2
FusionDSP1.0.36
Volumio 3.429
Thanks for this detailed explanation. I’ll try to reproduce it.
Hi, I am using Fusion for PEQ filter, it works well.
Now I am trying to use FIR filter computed with REW and Rephase.
I export impulse file at 96 Khz in DBL or 16 bit Wav format, then fusion tells that it verifies clipping and then stop workinf after few seconds. The volumio interface is frozen therefore i can acces to volumio only with SSH.
I am using latest version of volumio with a RPI3.
Is these somebody using FIR filter with fusion volumio, and is it working ? How do you parameters Fusion, what kind of filter format to be use , are we oblige forcing volumio to resample all to 96 Khz ?
Thank,
Thierry
Hello. I noticed a error when clipping detection is used with last version. But it is not supposed to freeze.
Your filters may require attenuation though.
Disable clipping detection and apply filter. Then enable pure Camilla gui’ in an other window.
Play something and check if clipping occurs.
If yes, you have to add enough attenuation to avoid clipping.
I’ll fix it soon.
I just try the files you provide with the installation of Fusion (Phase inversion left and right) in PCM format, it’s exactly the same.
Now as you suggest, I will put an attenuation ie 6 db and diseable clipping detection.
I keep you informed…
Thank for you support.
Thierry
So I confirm, the fact to desactivate clipping detection , , the Volumio interface is no more frozen, then impossible to play music, I can change the song, but when I put play nothing append, the time is frozen, it’s not playing.
Other thing, before and after rebooting, impossible to access to Camilla !!
Weird…
I do not provide file called phase inversion…
I use fir for month without issue.
The only issue with last 3 versions is that clipping is not detected properly and always set with -3dB instead of the correct value.
One other point, refresh the page if you add or remove filters from the Fir folder. Because if you remove a filter, without refresh it is still available in the scrolling list, but if you select it, it will fail.
So please test with files provided (demo_xxx).
And send log when it hangs.
TY
