Hello everybody, I been trying to get help from Volumio support but no answer in 10 days. Does anyone know how to address the problem? If it requires a reinstall of volumio in the dac, can anyone suggest a more stable software?
Problem description:
My system worked fine until december last year. A local wifi network as well as an ethernet cable from the same router to an Okto Research dac8 (raspberry pi 4) running Volumio. I could play either directly from the spotify app on my iphone 13 pro, or via the volumio app on the same phone.
Changes in december: update of iOS software to the 17 version on the phone (a lot of users at the apple community forum, including me, reported that the phone remote doesn’t work any more on appletv, some guessed it is wifi related) + I downgraded from Volumio Premium to Free.
The dac won’t play either from spotify or volumio on iphone or macbook although both connected to the local wifi network (the volumio app opens on both displaying correct dac, all playlists and such). The tune turns up, but music won’t play through the dac. If I try the internet radio in the volumio app, there is a “fail to open ‘alsa’ device volumio” message for all radio stations. No other error messages.
I’ve tried restarting the iphone and the relevant apps, nothing happens. I’m no expert on networks settings, and I don’t intend to be, but this problem shouldn’t appear since I haven’t changed anything.
Anyone has any idea why my system doesn’t work anymore? I can only suspect the iOS software or the change from Volumio Premium to Free, no other parameters has been changed (no update of dac firmware, no OSX update on laptop). I don’t know how to provide a log since I can’t find any option in the volumio software to generate one.
Best!
