I have the following problem: when I try to access the plugins tab the following message appears:
Please login
To access the plugins store you need to login to MyVolumio
Both the “Installed Plugin” and “Find Plugin” sections are empty.
The login with a myVolumio free account has obviously already been done. I tried to log out and log in several times, I tried to cancel my free account and create another one. Performed a new clean installation. The problem persists.
Hello @Palli. When I had this problem it turned out to be a network issue. In the Settings/Network menu, try selecting automatic IP for wireless netorking.
If that doesn’t help, as a test, try connecting your system with an ethernet cable and retrying.
If it works, then you know it’s wifi, possibly the country code, which can be specified in the wpa_supplicant.conf file.
Hello @SimonE, thanks for reach me. I follow your suggestion and I’ve just perform another clean installation without configure Wifi on Volumio startup configuration. But the problem remains also with the ethernet cable, the message:
Please login
Did not appear this time.
Thanks again for the support.
Flashed the sd, turned on my sbc, performed volumio guided configuration with Ethernet cable skipping wifi section, performed login of my volumio account throught the guided configuration and lastly i tried to go to plugin section, did not receive error but the tab plugin ‘find’ and ‘installed’ were empty.
Your connection to this web page is not safe due to a revoked security certificate.
Revoked certificates are usually fraudulently obtained or used and represent a risk for the way your data is handled.
