Empty plugins management tab
http://logs.volumio.org/volumio/Zg1jorj.html
In your logs, the plugin server was unreachable.
WARNING!!! Some remote endpoints cannot be reached!
Failing endpoints:
http://plugins.volumio.org, 526 ms
I just looked at mine and all endpoints are ok, so no CURRENT problems at the Volumio side:
http://plugins.volumio.org, 974 ms: OK
Maybe try again?
That is the url for the old store, the new myVolumio store is located at probably a myVolumio endpoint.
Either way, outside my prerogative, you’ll have to wait until some of the core guys who work on the myVolumio parts have a look at your log…
Before the upgrade to volumio3 everything works fine…. I tried also this morning to do a startup but always fail to reach plugin address
Hi Guys!
Same trouble here. I upgaded my raspberry to bookworm and after that I upgrade my volumio to the newest version.
I checked endpoints, everything is fine.
I checked my date, everything is fine.
I log out from my volumio and log in, that’s not help at all.
When i click on “Plugins” tab i can see nothing.
help please.
Hi @PatrickComel
  1. Indeed make sure that the date is set correctly
  2. Delete the device from myVolumio
  3. Reboot your devicce
  4. Login to my volumio
  5. If needed activate the device by pressing the green “Play” icon
  6. Check if it is OK now.
Unluckly this doesn’t help.
I’m not Russian btw, I’m Polish.
I just wanted to tell you because i saw simillar posts.
then please post a log.
http://logs.volumio.org/undefined/zqdtyiW.html
Go in IP/dev and enable beta or test mode.
Check if ok
It’s not that. I did it. Even right now, I press “true”, same problem, than I press “false”, same problem, I clicked “true” again and there is no different.
I’m not talking about plugin test mode but volumio. This is the first line. I can’t send a screenshot now but you should find it.
No I can’t find it
Update Channel Selection, select “Test”
Omg, my Bad sorry :smiley: , I feel so dummy :dizzy_face:
I select that option but still there is no plugins on my list.
@balbuze Any idea what is happening?
Jul 02 11:32:31 spedycja volumio[965]: info: CoreCommandRouter::executeOnPlugin: my_volumio , getMyVolumioStatus
Jul 02 11:32:31 spedycja volumio[965]: info: CoreCommandRouter::executeOnPlugin: my_volumio , getMyVolumioToken
Jul 02 11:32:32 spedycja volumio[965]: error: Cannot download Available plugins list: Error: got 404 response
You can check your network with the command in ssh
volumio endpointstest
I did that. Everything was great.
You know what, I just redownload the newest version, reinstall the whole software and now it’s works like a dream.
Thank you very much for your time! I reallly appreciate that.
