Hi all,
Im looking for a sollution the activate the sleep timer, or to delay toggle.
I tried using this py script from SANGERA2
But for some reason it only shuts down my player instead of stopping the music.
#PLAY PAUSE TOGGLE
KEY_ENTER 1 /usr/local/bin/volumio toggle
Is there a quick for this ? Can i add a delay in the command above ? How ?
Related topics :
Wheaten
2
Why not just using time.sleep(5) and avoid doing this via the socket.io?
Wheaten
4
was referring to your python script.
If you want to do it form bash you need something like:
/bin/bash -c "sleep 30; command to execute"
Still have no idea how i should do this.
I tried adjusting my trigger happy config file to
#ACTIVATE SLEEP
KEY_ENTER 1 /bin/bash -c "sleep 30; command to execute"
But this doenst work
Wheaten
6
it should as I am using it also here:
YES, Thank you !
Took me a while to understand what you ment with ‘command to execute’
#TOGGLE PLAY/PAUSE AFTER 1 HOUR
KEY_ENTER 1 /bin/bash -c “sleep 3600; /usr/local/bin/volumio toggle”
