i asked the creator and got a update he will get on it when he has a little time.
best regards,
dvo
best regards,
dvo
is it somehow possible to connect 2 displays? 1 for volumio interface 1 for peppymeter ?
I have this not checked. Per default Peppymeter write to DISPLAY=:0
Itâs defined in:
/data/plugins/miscellanea/peppy_screensaver/peppymeter/config.txt
and
/data/plugins/miscellanea/peppy_screensaver/peppymeter/run_peppymeter.sh
You can try to change it to DISPLAY=:1 the second display and use the first for volumio.
But I have not thest this.
I have check now the contemporary plugin with buster 3.198: it works. The css files are not changed with this Volumio version.
No update of plugin is needed
Hi together,
I have update the plugin to V 1.0.6 with support of VOLUMIO Buster 3.233.
The latest css files start with app-10âŚcss.
To use the update do the follow:
volumio plugin update
Best regards and have fun
I got my screen from post office today. Waveshare 7.9" capacitive touchscreen with 1280x400 resolution.
I tinkered around a bit with the plugin settings and got the layout mostly working nicely, but there is small issue with track information vertical positioning. I would like to center it or at least move down a little bit vertically, but could not find good way for this. There is that âTrack information container positionâ setting that suppose to move it vertically (or at least I understand, it should, the info button text is not too informative), but changing it does nothing. At the moment the track name is too close to Back button and I want to move it a little bit lower. How can I achieve this?
Edit: After some more time spent, it seems to be tied to UI scaling, if I turn it off, then this positioning parameter works, but playing buttons and slider bar will be then too small. Is it possible to change size for slider and play buttons separately?
hello, thank you for your preliminary work with the 8.8 inch display. but when i use your file from i have no volume indicator or i can see volume displayed on the phone screen ! or did I overlook the solution for this?
Yes you are right, there is no volume indicator but Afaik in whole contemporary design, you donât see volume indicator.
P.S. for version 2.9xxx and 3xx, better solution in my opinion is to use ânow playingâ plugin, especially with this screen.
Does this work with the latest version 3.251?
no the plugin is not yet updated for the latest version.
Mostly I have got this plugin tweaked as I like. But one thing is left that I havenât figured out, how to solve without changing overall scale factor (that messes up the layout). The size of slider bar and play buttons. At the moment these are quite hard to touch, because they are too small:
Could I change the size of them somehow?
does the now playing plugin work along with peppymeter as a screen saver?
Yes it does, and you can decide when (after xx secs) should peppy meter run as screen saver, till this moment you will see ânow playingâ screen.
how set it for 50 inch 4k tv. ?
I will pay for this help
You donât have to pay here. You will surely find a solution. This is a forum of âgood peopleâ
First, write what you want to set?
Thanks for the reply. I got it up and running. Just need to figure out how to make it work with Spotify or just have it show only for local files
I donât use spotify, but i think there was some issue with spotify - you can ask author here [PLUGIN] Now Playing - #246 by patrickkfkan
now playing works fine with spotify. I meant peppymeters
Yes sorry my mistake, wrong link here is correct link Project with PeppyMeter Screensaver Plugin for VOLUMIO v2.9xx and 3.0xx buster - #803 by tyzwyzb
As far as I am aware, cover art, track info and time remaining are working. the VU meters are not working for SPOP.
