Slowlyness comes only after changing of the following file:
sudo nano /etc/X11/xorg.conf.d/99-calibration.conf
Output of cat /var/log/Xorg.0.log is as follows:
volumio@t:~$ cat /var/log/Xorg.0.log
[ 31.864]
X.Org X Server 1.18.4
Release Date: 2016-07-19
[ 31.864] X Protocol Version 11, Revision 0
[ 31.864] Build Operating System: Linux 4.4.26-v7+ armv7l Raspbian
[ 31.864] Current Operating System: Linux t 4.19.118-v7l+ #1311 SMP Mon Apr 27 14:26:42 BST 2020 armv7l
[ 31.864] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 cma=64M bcm2708_fb.fbwidth=640 bcm2708_fb.fbheight=480 bcm2708_fb.fbswap=1 smsc95xx.macaddr=E4:5F:01:2A:9F:74 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 splash quiet plymouth.ignore-serial-consoles dwc_otg.fiq_enable=1 dwc_otg.fiq_fsm_enable=1 dwc_otg.fiq_fsm_mask=0xF dwc_otg.nak_holdoff=1 console=ttyS0,115200 kgdboc=ttyS0,115200 console=tty1 imgpart=/dev/mmcblk0p2 imgfile=/volumio_current.sqsh elevator=noop rootwait bootdelay=5 logo.nologo vt.global_cursor_default=0 loglevel=0 snd-bcm2835.enable_compat_alsa=1 snd_bcm2835.enable_headphones=1
[ 31.864] Build Date: 11 November 2016 11:59:59AM
[ 31.864] xorg-server 2:1.18.4-2+rpi1 (https://www.debian.org/support)
[ 31.864] Current version of pixman: 0.32.6
[ 31.864] Before reporting problems, check http://wiki.x.org
[ 31.864] Markers: (--) probed, (**) from config file, (==) default setting,
[ 31.865] (==) Log file: "/var/log/Xorg.0.log", Time: Sun Jun 27 10:12:53 2021
[ 31.872] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 31.872] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 31.880] (==) No Layout section. Using the first Screen section.
[ 31.880] (==) No screen section available. Using defaults.
[ 31.880] (**) |-->Screen "Default Screen Section" (0)
[ 31.880] (**) | |-->Monitor "<default monitor>"
[ 31.883] (==) No device specified for screen "Default Screen Section".
Using the first device section listed.
[ 31.883] (**) | |-->Device "Allwinner A10/A13 FBDEV"
[ 31.883] (==) No monitor specified for screen "Default Screen Section".
[ 31.883] (==) Automatically adding devices
[ 31.883] (==) Automatically enabling devices
[ 31.883] (==) Automatically adding GPU devices
[ 31.887] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 31.890] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[ 31.890] Entry deleted from font path.
[ 31.892] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
/usr/share/fonts/X11/100dpi,
/usr/share/fonts/X11/75dpi,
built-ins
[ 31.892] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 31.892] (II) The server relies on udev to provide the list of input devices.
[ 31.892] (II) Loader magic: 0x6c1f20
[ 31.892] (II) Module ABI versions:
[ 31.892] X.Org ANSI C Emulation: 0.4
[ 31.892] X.Org Video Driver: 20.0
[ 31.892] X.Org XInput driver : 22.1
[ 31.892] X.Org Server Extension : 9.0
[ 31.894] (--) using VT number 2
[ 31.894] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 31.894] (II) no primary bus or device found
[ 31.895] (II) LoadModule: "glx"
[ 31.897] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 31.936] (II) Module glx: vendor="X.Org Foundation"
[ 31.936] compiled for 1.18.4, module version = 1.0.0
[ 31.936] ABI class: X.Org Server Extension, version 9.0
[ 31.936] (==) AIGLX enabled
[ 31.936] (II) LoadModule: "fbturbo"
[ 31.937] (II) Loading /usr/lib/xorg/modules/drivers/fbturbo_drv.so
[ 31.941] (II) Module fbturbo: vendor="X.Org Foundation"
[ 31.941] compiled for 1.18.4, module version = 0.5.1
[ 31.941] Module class: X.Org Video Driver
[ 31.941] ABI class: X.Org Video Driver, version 20.0
[ 31.941] (II) FBTURBO: driver for framebuffer: fbturbo
[ 31.942] (WW) Falling back to old probe method for fbturbo
[ 31.942] (II) Loading sub module "fbdevhw"
[ 31.942] (II) LoadModule: "fbdevhw"
[ 31.942] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[ 31.945] (II) Module fbdevhw: vendor="X.Org Foundation"
[ 31.945] compiled for 1.18.4, module version = 0.0.2
[ 31.945] ABI class: X.Org Video Driver, version 20.0
[ 31.945] (II) FBTURBO(0): using /dev/fb1
[ 31.945] (II) FBTURBO(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 16/16
[ 31.945] (==) FBTURBO(0): Depth 16, (==) framebuffer bpp 16
[ 31.945] (==) FBTURBO(0): RGB weight 565
[ 31.945] (==) FBTURBO(0): Default visual is TrueColor
[ 31.945] (==) FBTURBO(0): Using gamma correction (1.0, 1.0, 1.0)
[ 31.945] (II) FBTURBO(0): hardware: fb_ili9486 (video memory: 300kB)
[ 31.945] (**) FBTURBO(0): Option "fbdev" "/dev/fb1"
[ 31.945] (**) FBTURBO(0): Option "SwapbuffersWait" "true"
[ 31.945] (II) FBTURBO(0): processor: Unknown
[ 31.945] (II) FBTURBO(0): checking modes against framebuffer device...
[ 31.945] (II) FBTURBO(0): checking modes against monitor...
[ 31.945] (--) FBTURBO(0): Virtual size is 480x320 (pitch 480)
[ 31.945] (**) FBTURBO(0): Built-in mode "current"
[ 31.945] (==) FBTURBO(0): DPI set to (96, 96)
[ 31.945] (II) Loading sub module "fb"
[ 31.945] (II) LoadModule: "fb"
[ 31.946] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 31.950] (II) Module fb: vendor="X.Org Foundation"
[ 31.950] compiled for 1.18.4, module version = 1.0.0
[ 31.950] ABI class: X.Org ANSI C Emulation, version 0.4
[ 31.950] (II) FBTURBO(0): FBIOBLANK: Invalid argument (Screen blanking not supported by kernel - disabling)
[ 31.962] (II) FBTURBO(0): using backing store heuristics
[ 31.967] (II) FBTURBO(0): can't load 'g2d_23' kernel module
[ 31.967] (II) FBTURBO(0): failed to enable the use of sunxi display controller
[ 31.967] (II) FBTURBO(0): No sunxi-g2d hardware detected (check /dev/disp and /dev/g2d)
[ 31.967] (II) FBTURBO(0): G2D hardware acceleration can't be enabled
[ 31.967] (II) FBTURBO(0): enabled VFP/NEON optimizations
[ 31.967] (==) FBTURBO(0): Backing store enabled
[ 31.982] (==) FBTURBO(0): DPMS enabled
[ 31.982] (II) FBTURBO(0): failed to enable hardware cursor
[ 31.982] (II) FBTURBO(0): no 3D acceleration because the driver has been compiled without libUMP
[ 31.982] (II) FBTURBO(0): if this is wrong and needs to be fixed, please check ./configure log
[ 31.983] (==) RandR enabled
[ 31.999] (II) SELinux: Disabled on system
[ 32.002] (II) AIGLX: Screen 0 is not DRI2 capable
[ 32.003] (EE) AIGLX: reverting to software rendering
[ 32.794] (II) AIGLX: enabled GLX_MESA_copy_sub_buffer
[ 32.795] (II) AIGLX: Loaded and initialized swrast
[ 32.795] (II) GLX: Initialized DRISWRAST GL provider for screen 0
[ 32.943] (II) config/udev: Adding input device ADS7846 Touchscreen (/dev/input/event0)
[ 32.943] (**) ADS7846 Touchscreen: Applying InputClass "evdev touchscreen catchall"
[ 32.943] (**) ADS7846 Touchscreen: Applying InputClass "libinput touchscreen catchall"
[ 32.943] (**) ADS7846 Touchscreen: Applying InputClass "Touch rotation"
[ 32.943] (**) ADS7846 Touchscreen: Applying InputClass "calibration"
[ 32.943] (II) LoadModule: "evdev"
[ 32.944] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[ 32.952] (II) Module evdev: vendor="X.Org Foundation"
[ 32.952] compiled for 1.18.4, module version = 2.10.3
[ 32.953] Module class: X.Org XInput Driver
[ 32.953] ABI class: X.Org XInput driver, version 22.1
[ 32.953] (II) Using input driver 'evdev' for 'ADS7846 Touchscreen'
[ 32.953] (**) ADS7846 Touchscreen: always reports core events
[ 32.953] (**) evdev: ADS7846 Touchscreen: Device: "/dev/input/event0"
[ 32.953] (--) evdev: ADS7846 Touchscreen: Vendor 0 Product 0
[ 32.953] (--) evdev: ADS7846 Touchscreen: Found absolute axes
[ 32.953] (--) evdev: ADS7846 Touchscreen: Found x and y absolute axes
[ 32.953] (--) evdev: ADS7846 Touchscreen: Found absolute touchscreen
[ 32.953] (**) Option "SwapAxes" "1"
[ 32.953] (II) evdev: ADS7846 Touchscreen: Configuring as touchscreen
[ 32.953] (**) evdev: ADS7846 Touchscreen: YAxisMapping: buttons 4 and 5
[ 32.953] (**) evdev: ADS7846 Touchscreen: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 32.953] (**) Option "config_info" "udev:/sys/devices/platform/soc/fe204000.spi/spi_master/spi0/spi0.1/input/input0/event0"
[ 32.953] (II) XINPUT: Adding extended input device "ADS7846 Touchscreen" (type: TOUCHSCREEN, id 6)
[ 32.953] (II) evdev: ADS7846 Touchscreen: initialized for absolute axes.
[ 32.953] (**) ADS7846 Touchscreen: (accel) keeping acceleration scheme 1
[ 32.953] (**) ADS7846 Touchscreen: (accel) acceleration profile 0
[ 32.953] (**) ADS7846 Touchscreen: (accel) acceleration factor: 2.000
[ 32.953] (**) ADS7846 Touchscreen: (accel) acceleration threshold: 4
[ 32.954] (II) config/udev: Adding input device ADS7846 Touchscreen (/dev/input/mouse0)
[ 32.954] (**) ADS7846 Touchscreen: Applying InputClass "calibration"
[ 32.954] (II) No input driver specified, ignoring this device.
[ 32.954] (II) This device may have been added with another device file.
