volumio@t:~$ cat /var/log/Xorg.0.log
[ 58.919]
X.Org X Server 1.18.4
Release Date: 2016-07-19
[ 58.919] X Protocol Version 11, Revision 0
[ 58.919] Build Operating System: Linux 4.4.26-v7+ armv7l Raspbian
[ 58.919] Current Operating System: Linux t 4.19.118-v7l+ #1311 SMP Mon Apr 2 7 14:26:42 BST 2020 armv7l
[ 58.919] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 cma=64M bcm27 08_fb.fbwidth=640 bcm2708_fb.fbheight=480 bcm2708_fb.fbswap=1 smsc95xx.macaddr=E 4:5F:01:2A:9F:74 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 splash q uiet plymouth.ignore-serial-consoles dwc_otg.fiq_enable=1 dwc_otg.fiq_fsm_enable =1 dwc_otg.fiq_fsm_mask=0xF dwc_otg.nak_holdoff=1 console=ttyS0,115200 kgdboc=tt yS0,115200 console=tty1 imgpart=/dev/mmcblk0p2 imgfile=/volumio_current.sqsh ele vator=noop rootwait bootdelay=5 logo.nologo vt.global_cursor_default=0 loglevel= 0 snd-bcm2835.enable_compat_alsa=1 snd_bcm2835.enable_headphones=1
[ 58.919] Build Date: 11 November 2016 11:59:59AM
[ 58.919] xorg-server 2:1.18.4-2+rpi1 (Debian -- Support)
[ 58.919] Current version of pixman: 0.32.6
[ 58.919] Before reporting problems, check http://wiki.x.org
[ 58.919] Markers: (–) probed, () from config file, (==) default setting,
[ 58.920] (==) Log file: “/var/log/Xorg.0.log”, Time: Fri Jun 18 13:43:47 202 1
[ 58.923] (==) Using config directory: “/etc/X11/xorg.conf.d”
[ 58.923] (==) Using system config directory “/usr/share/X11/xorg.conf.d”
[ 58.930] (==) No Layout section. Using the first Screen section.
[ 58.930] (==) No screen section available. Using defaults.
[ 58.930] () |–>Screen “Default Screen Section” (0)
[ 58.930] () | |–>Monitor “”
[ 58.933] (==) No device specified for screen “Default Screen Section”.
Using the first device section listed.
[ 58.933] () | |–>Device “Allwinner A10/A13 FBDEV”
[ 58.933] (==) No monitor specified for screen “Default Screen Section”.
[ 58.933] (==) Automatically adding devices
[ 58.933] (==) Automatically enabling devices
[ 58.933] (==) Automatically adding GPU devices
[ 58.937] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 58.938] (WW) The directory “/usr/share/fonts/X11/cyrillic” does not exist.
[ 58.938] Entry deleted from font path.
[ 58.940] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
/usr/share/fonts/X11/100dpi,
/usr/share/fonts/X11/75dpi,
built-ins
[ 58.940] (==) ModulePath set to “/usr/lib/xorg/modules”
[ 58.940] (II) The server relies on udev to provide the list of input devices .
If no devices become available, reconfigure udev or disable AutoAddDevic es.
[ 58.940] (II) Loader magic: 0x666f20
[ 58.940] (II) Module ABI versions:
[ 58.940] X.Org ANSI C Emulation: 0.4
[ 58.940] X.Org Video Driver: 20.0
[ 58.940] X.Org XInput driver : 22.1
[ 58.940] X.Org Server Extension : 9.0
[ 58.941] (–) using VT number 2
[ 58.941] (II) systemd-logind: logind integration requires -keeptty and -keep tty was not provided, disabling logind integration
[ 58.942] (II) no primary bus or device found
[ 58.943] (II) LoadModule: “glx”
[ 58.944] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 58.982] (II) Module glx: vendor=“X.Org Foundation”
[ 58.982] compiled for 1.18.4, module version = 1.0.0
[ 58.982] ABI class: X.Org Server Extension, version 9.0
[ 58.982] (==) AIGLX enabled
[ 58.982] (II) LoadModule: “fbturbo”
[ 58.983] (II) Loading /usr/lib/xorg/modules/drivers/fbturbo_drv.so
[ 58.985] (II) Module fbturbo: vendor=“X.Org Foundation”
[ 58.985] compiled for 1.18.4, module version = 0.5.1
[ 58.985] Module class: X.Org Video Driver
[ 58.985] ABI class: X.Org Video Driver, version 20.0
[ 58.985] (II) FBTURBO: driver for framebuffer: fbturbo
[ 58.987] (WW) Falling back to old probe method for fbturbo
[ 58.987] (II) Loading sub module “fbdevhw”
[ 58.987] (II) LoadModule: “fbdevhw”
[ 58.987] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[ 58.988] (II) Module fbdevhw: vendor=“X.Org Foundation”
[ 58.988] compiled for 1.18.4, module version = 0.0.2
[ 58.988] ABI class: X.Org Video Driver, version 20.0
[ 58.988] (II) FBTURBO(0): using /dev/fb0
[ 58.988] (II) FBTURBO(0): Creating default Display subsection in Screen sect ion
“Default Screen Section” for depth/fbbpp 24/32
[ 58.988] (==) FBTURBO(0): Depth 24, (==) framebuffer bpp 32
[ 58.988] (==) FBTURBO(0): RGB weight 888
[ 58.988] (==) FBTURBO(0): Default visual is TrueColor
[ 58.988] (==) FBTURBO(0): Using gamma correction (1.0, 1.0, 1.0)
[ 58.988] (II) FBTURBO(0): hardware: BCM2708 FB (video memory: 1200kB)
[ 58.988] () FBTURBO(0): Option “fbdev” “/dev/fb0”
[ 58.988] () FBTURBO(0): Option “SwapbuffersWait” “true”
[ 58.989] (II) FBTURBO(0): processor: Unknown
[ 58.989] (II) FBTURBO(0): checking modes against framebuffer device…
[ 58.989] (II) FBTURBO(0): checking modes against monitor…
[ 58.989] (–) FBTURBO(0): Virtual size is 640x480 (pitch 640)
[ 58.989] () FBTURBO(0): Built-in mode “current”
[ 58.989] (==) FBTURBO(0): DPI set to (96, 96)
[ 58.989] (II) Loading sub module “fb”
[ 58.989] (II) LoadModule: “fb”
[ 58.990] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 58.994] (II) Module fb: vendor=“X.Org Foundation”
[ 58.994] compiled for 1.18.4, module version = 1.0.0
[ 58.994] ABI class: X.Org ANSI C Emulation, version 0.4
[ 58.994] (==) Depth 24 pixmap format is 32 bpp
[ 59.007] (II) FBTURBO(0): using backing store heuristics
[ 59.013] (II) FBTURBO(0): can’t load ‘g2d_23’ kernel module
[ 59.013] (II) FBTURBO(0): failed to enable the use of sunxi display controll er
[ 59.013] (II) FBTURBO(0): No sunxi-g2d hardware detected (check /dev/disp an d /dev/g2d)
[ 59.013] (II) FBTURBO(0): G2D hardware acceleration can’t be enabled
[ 59.013] (II) FBTURBO(0): enabled fbdev copyarea acceleration
[ 59.013] (==) FBTURBO(0): Backing store enabled
[ 59.019] (==) FBTURBO(0): DPMS enabled
[ 59.019] (II) FBTURBO(0): failed to enable hardware cursor
[ 59.019] (II) FBTURBO(0): no 3D acceleration because the driver has been com piled without libUMP
[ 59.019] (II) FBTURBO(0): if this is wrong and needs to be fixed, please che ck ./configure log
[ 59.020] (==) RandR enabled
[ 59.036] (II) SELinux: Disabled on system
[ 59.039] (II) AIGLX: Screen 0 is not DRI2 capable
[ 59.039] (EE) AIGLX: reverting to software rendering
[ 59.664] (II) AIGLX: enabled GLX_MESA_copy_sub_buffer
[ 59.665] (II) AIGLX: Loaded and initialized swrast
[ 59.665] (II) GLX: Initialized DRISWRAST GL provider for screen 0
[ 59.809] (II) config/udev: Adding input device ADS7846 Touchscreen (/dev/inp ut/event0)
[ 59.809] () ADS7846 Touchscreen: Applying InputClass “libinput touchscreen catchall”
[ 59.809] () ADS7846 Touchscreen: Applying InputClass “Touch rotation”
[ 59.809] () ADS7846 Touchscreen: Applying InputClass “calibration”
[ 59.809] (II) LoadModule: “libinput”
[ 59.810] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 59.828] (II) Module libinput: vendor=“X.Org Foundation”
[ 59.828] compiled for 1.18.4, module version = 0.20.0
[ 59.828] Module class: X.Org XInput Driver
[ 59.828] ABI class: X.Org XInput driver, version 22.1
[ 59.828] (II) Using input driver ‘libinput’ for ‘ADS7846 Touchscreen’
[ 59.828] () ADS7846 Touchscreen: always reports core events
[ 59.828] () Option “Device” “/dev/input/event0”
[ 59.828] () Option “_source” “server/udev”
[ 59.829] (II) input device ‘ADS7846 Touchscreen’, /dev/input/event0 is tagge d by udev as: Touchscreen
[ 59.829] (II) input device ‘ADS7846 Touchscreen’, /dev/input/event0 is a tou ch device
[ 59.860] () Option “config_info” “udev:/sys/devices/platform/soc/fe204000. spi/spi_master/spi0/spi0.1/input/input0/event0”
[ 59.860] (II) XINPUT: Adding extended input device “ADS7846 Touchscreen” (ty pe: TOUCHSCREEN, id 6)
[ 59.860] () Option “AccelerationScheme” “none”
[ 59.860] () ADS7846 Touchscreen: (accel) selected scheme none/0
[ 59.860] () ADS7846 Touchscreen: (accel) acceleration factor: 2.000
[ 59.860] () ADS7846 Touchscreen: (accel) acceleration threshold: 4
[ 59.861] (II) input device ‘ADS7846 Touchscreen’, /dev/input/event0 is tagge d by udev as: Touchscreen
[ 59.861] (II) input device ‘ADS7846 Touchscreen’, /dev/input/event0 is a tou ch device
[ 59.861] (II) config/udev: Adding input device ADS7846 Touchscreen (/dev/inp ut/mouse0)
[ 59.861] (**) ADS7846 Touchscreen: Applying InputClass “calibration”
[ 59.861] (II) No input driver specified, ignoring this device.
[ 59.861] (II) This device may have been added with another device file.
Volumio again not reachable via mobile . . .
SSH access is possible (although no IP is shown in Putty) as I can swith between different directories via Putty.
EDIT: And again only after a few minutes of waiting, Volumio GUI is available again via my mobile
