Touch is still mirrored:
volumio@t:~$ cat /var/log/Xorg.0.log
[ 32.353]
X.Org X Server 1.18.4
Release Date: 2016-07-19
[ 32.353] X Protocol Version 11, Revision 0
[ 32.353] Build Operating System: Linux 4.4.26-v7+ armv7l Raspbian
[ 32.353] Current Operating System: Linux t 4.19.118-v7l+ #1311 SMP Mon Apr 2 7 14:26:42 BST 2020 armv7l
[ 32.353] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 cma=64M bcm27 08_fb.fbwidth=640 bcm2708_fb.fbheight=480 bcm2708_fb.fbswap=1 smsc95xx.macaddr=E 4:5F:01:2A:9F:74 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 splash q uiet plymouth.ignore-serial-consoles dwc_otg.fiq_enable=1 dwc_otg.fiq_fsm_enable =1 dwc_otg.fiq_fsm_mask=0xF dwc_otg.nak_holdoff=1 console=ttyS0,115200 kgdboc=tt yS0,115200 console=tty1 imgpart=/dev/mmcblk0p2 imgfile=/volumio_current.sqsh ele vator=noop rootwait bootdelay=5 logo.nologo vt.global_cursor_default=0 loglevel= 0 snd-bcm2835.enable_compat_alsa=1 snd_bcm2835.enable_headphones=1
[ 32.353] Build Date: 11 November 2016 11:59:59AM
[ 32.353] xorg-server 2:1.18.4-2+rpi1 (Debian -- Support)
[ 32.353] Current version of pixman: 0.32.6
[ 32.353] Before reporting problems, check http://wiki.x.org
[ 32.353] Markers: (–) probed, () from config file, (==) default setting,
[ 32.353] (==) Log file: “/var/log/Xorg.0.log”, Time: Thu Jun 24 16:15:18 202 1
[ 32.357] (==) Using config directory: “/etc/X11/xorg.conf.d”
[ 32.357] (==) Using system config directory “/usr/share/X11/xorg.conf.d”
[ 32.364] (==) No Layout section. Using the first Screen section.
[ 32.364] (==) No screen section available. Using defaults.
[ 32.364] () |–>Screen “Default Screen Section” (0)
[ 32.364] () | |–>Monitor “”
[ 32.369] (==) No device specified for screen “Default Screen Section”.
Using the first device section listed.
[ 32.369] () | |–>Device “Allwinner A10/A13 FBDEV”
[ 32.369] (==) No monitor specified for screen “Default Screen Section”.
[ 32.369] (==) Automatically adding devices
[ 32.369] (==) Automatically enabling devices
[ 32.369] (==) Automatically adding GPU devices
[ 32.372] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 32.374] (WW) The directory “/usr/share/fonts/X11/cyrillic” does not exist.
[ 32.374] Entry deleted from font path.
[ 32.377] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
/usr/share/fonts/X11/100dpi,
/usr/share/fonts/X11/75dpi,
built-ins
[ 32.377] (==) ModulePath set to “/usr/lib/xorg/modules”
[ 32.377] (II) The server relies on udev to provide the list of input devices .
If no devices become available, reconfigure udev or disable AutoAddDevic es.
[ 32.377] (II) Loader magic: 0x68bf20
[ 32.377] (II) Module ABI versions:
[ 32.377] X.Org ANSI C Emulation: 0.4
[ 32.377] X.Org Video Driver: 20.0
[ 32.377] X.Org XInput driver : 22.1
[ 32.377] X.Org Server Extension : 9.0
[ 32.378] (–) using VT number 2
[ 32.379] (II) systemd-logind: logind integration requires -keeptty and -keep tty was not provided, disabling logind integration
[ 32.379] (II) no primary bus or device found
[ 32.380] (II) LoadModule: “glx”
[ 32.382] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 32.425] (II) Module glx: vendor=“X.Org Foundation”
[ 32.425] compiled for 1.18.4, module version = 1.0.0
[ 32.425] ABI class: X.Org Server Extension, version 9.0
[ 32.425] (==) AIGLX enabled
[ 32.425] (II) LoadModule: “fbturbo”
[ 32.426] (II) Loading /usr/lib/xorg/modules/drivers/fbturbo_drv.so
[ 32.430] (II) Module fbturbo: vendor=“X.Org Foundation”
[ 32.430] compiled for 1.18.4, module version = 0.5.1
[ 32.430] Module class: X.Org Video Driver
[ 32.430] ABI class: X.Org Video Driver, version 20.0
[ 32.430] (II) FBTURBO: driver for framebuffer: fbturbo
[ 32.431] (WW) Falling back to old probe method for fbturbo
[ 32.431] (II) Loading sub module “fbdevhw”
[ 32.431] (II) LoadModule: “fbdevhw”
[ 32.432] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[ 32.434] (II) Module fbdevhw: vendor=“X.Org Foundation”
[ 32.434] compiled for 1.18.4, module version = 0.0.2
[ 32.434] ABI class: X.Org Video Driver, version 20.0
[ 32.434] (II) FBTURBO(0): using /dev/fb1
[ 32.434] (II) FBTURBO(0): Creating default Display subsection in Screen sect ion
“Default Screen Section” for depth/fbbpp 16/16
[ 32.434] (==) FBTURBO(0): Depth 16, (==) framebuffer bpp 16
[ 32.434] (==) FBTURBO(0): RGB weight 565
[ 32.434] (==) FBTURBO(0): Default visual is TrueColor
[ 32.434] (==) FBTURBO(0): Using gamma correction (1.0, 1.0, 1.0)
[ 32.434] (II) FBTURBO(0): hardware: fb_ili9486 (video memory: 300kB)
[ 32.434] () FBTURBO(0): Option “fbdev” “/dev/fb1”
[ 32.434] () FBTURBO(0): Option “SwapbuffersWait” “true”
[ 32.434] (II) FBTURBO(0): processor: Unknown
[ 32.434] (II) FBTURBO(0): checking modes against framebuffer device…
[ 32.434] (II) FBTURBO(0): checking modes against monitor…
[ 32.434] (–) FBTURBO(0): Virtual size is 480x320 (pitch 480)
[ 32.434] () FBTURBO(0): Built-in mode “current”
[ 32.434] (==) FBTURBO(0): DPI set to (96, 96)
[ 32.434] (II) Loading sub module “fb”
[ 32.434] (II) LoadModule: “fb”
[ 32.436] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 32.440] (II) Module fb: vendor=“X.Org Foundation”
[ 32.440] compiled for 1.18.4, module version = 1.0.0
[ 32.440] ABI class: X.Org ANSI C Emulation, version 0.4
[ 32.441] (II) FBTURBO(0): FBIOBLANK: Invalid argument (Screen blanking not s upported by kernel - disabling)
[ 32.452] (II) FBTURBO(0): using backing store heuristics
[ 32.459] (II) FBTURBO(0): can’t load ‘g2d_23’ kernel module
[ 32.459] (II) FBTURBO(0): failed to enable the use of sunxi display controll er
[ 32.459] (II) FBTURBO(0): No sunxi-g2d hardware detected (check /dev/disp an d /dev/g2d)
[ 32.459] (II) FBTURBO(0): G2D hardware acceleration can’t be enabled
[ 32.459] (II) FBTURBO(0): enabled VFP/NEON optimizations
[ 32.459] (==) FBTURBO(0): Backing store enabled
[ 32.465] (==) FBTURBO(0): DPMS enabled
[ 32.465] (II) FBTURBO(0): failed to enable hardware cursor
[ 32.465] (II) FBTURBO(0): no 3D acceleration because the driver has been com piled without libUMP
[ 32.465] (II) FBTURBO(0): if this is wrong and needs to be fixed, please che ck ./configure log
[ 32.467] (==) RandR enabled
[ 32.483] (II) SELinux: Disabled on system
[ 32.489] (II) AIGLX: Screen 0 is not DRI2 capable
[ 32.489] (EE) AIGLX: reverting to software rendering
[ 33.328] (II) AIGLX: enabled GLX_MESA_copy_sub_buffer
[ 33.329] (II) AIGLX: Loaded and initialized swrast
[ 33.329] (II) GLX: Initialized DRISWRAST GL provider for screen 0
[ 33.468] (II) config/udev: Adding input device RPI Wired Keyboard 5 (/dev/ input/event0)
[ 33.469] () RPI Wired Keyboard 5: Applying InputClass “libinput keyboard catchall”
[ 33.469] (II) LoadModule: “libinput”
[ 33.469] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 33.487] (II) Module libinput: vendor=“X.Org Foundation”
[ 33.487] compiled for 1.18.4, module version = 0.20.0
[ 33.487] Module class: X.Org XInput Driver
[ 33.487] ABI class: X.Org XInput driver, version 22.1
[ 33.487] (II) Using input driver ‘libinput’ for ’ RPI Wired Keyboard 5’
[ 33.487] () RPI Wired Keyboard 5: always reports core events
[ 33.487] () Option “Device” “/dev/input/event0”
[ 33.487] () Option “_source” “server/udev”
[ 33.488] (II) input device ’ RPI Wired Keyboard 5’, /dev/input/event0 is ta gged by udev as: Keyboard
[ 33.488] (II) input device ’ RPI Wired Keyboard 5’, /dev/input/event0 is a keyboard
[ 33.530] () Option “config_info” “udev:/sys/devices/platform/scb/fd500000. pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1.1/1-1.1.1:1.0/000 3:04D9:0006.0001/input/input0/event0”
[ 33.530] (II) XINPUT: Adding extended input device " RPI Wired Keyboard 5" (type: KEYBOARD, id 6)
[ 33.530] () Option “xkb_model” “pc105”
[ 33.530] () Option “xkb_layout” “us”
[ 33.531] (II) input device ’ RPI Wired Keyboard 5’, /dev/input/event0 is ta gged by udev as: Keyboard
[ 33.531] (II) input device ’ RPI Wired Keyboard 5’, /dev/input/event0 is a keyboard
[ 33.532] (II) config/udev: Adding input device RPI Wired Keyboard 5 (/dev/ input/event1)
[ 33.532] () RPI Wired Keyboard 5: Applying InputClass “libinput keyboard catchall”
[ 33.532] (II) Using input driver ‘libinput’ for ’ RPI Wired Keyboard 5’
[ 33.532] () RPI Wired Keyboard 5: always reports core events
[ 33.532] () Option “Device” “/dev/input/event1”
[ 33.532] () Option “_source” “server/udev”
[ 33.533] (II) input device ’ RPI Wired Keyboard 5’, /dev/input/event1 is ta gged by udev as: Keyboard
[ 33.533] (II) input device ’ RPI Wired Keyboard 5’, /dev/input/event1 is a keyboard
[ 33.570] () Option “config_info” “udev:/sys/devices/platform/scb/fd500000. pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1.1/1-1.1.1:1.1/000 3:04D9:0006.0002/input/input1/event1”
[ 33.570] (II) XINPUT: Adding extended input device " RPI Wired Keyboard 5" (type: KEYBOARD, id 7)
[ 33.570] () Option “xkb_model” “pc105”
[ 33.570] () Option “xkb_layout” “us”
[ 33.571] (II) input device ’ RPI Wired Keyboard 5’, /dev/input/event1 is ta gged by udev as: Keyboard
[ 33.571] (II) input device ’ RPI Wired Keyboard 5’, /dev/input/event1 is a keyboard
[ 33.572] (II) config/udev: Adding input device PixArt USB Optical Mouse (/de v/input/event2)
[ 33.572] () PixArt USB Optical Mouse: Applying InputClass “libinput pointe r catchall”
[ 33.572] (II) Using input driver ‘libinput’ for ‘PixArt USB Optical Mouse’
[ 33.572] () PixArt USB Optical Mouse: always reports core events
[ 33.572] () Option “Device” “/dev/input/event2”
[ 33.572] () Option “_source” “server/udev”
[ 33.572] (II) input device ‘PixArt USB Optical Mouse’, /dev/input/event2 is tagged by udev as: Mouse
[ 33.572] (II) input device ‘PixArt USB Optical Mouse’, /dev/input/event2 is a pointer caps
[ 33.640] () Option “config_info” “udev:/sys/devices/platform/scb/fd500000. pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1.4/1-1.1.4:1.0/000 3:093A:2510.0003/input/input2/event2”
[ 33.640] (II) XINPUT: Adding extended input device "PixArt USB Optical Mouse " (type: MOUSE, id 8)
[ 33.640] () Option “AccelerationScheme” “none”
[ 33.640] () PixArt USB Optical Mouse: (accel) selected scheme none/0
[ 33.640] () PixArt USB Optical Mouse: (accel) acceleration factor: 2.000
[ 33.640] () PixArt USB Optical Mouse: (accel) acceleration threshold: 4
[ 33.641] (II) input device ‘PixArt USB Optical Mouse’, /dev/input/event2 is tagged by udev as: Mouse
[ 33.641] (II) input device ‘PixArt USB Optical Mouse’, /dev/input/event2 is a pointer caps
[ 33.642] (II) config/udev: Adding input device PixArt USB Optical Mouse (/de v/input/mouse0)
[ 33.642] (II) No input driver specified, ignoring this device.
[ 33.642] (II) This device may have been added with another device file.
[ 33.642] (II) config/udev: Adding input device ADS7846 Touchscreen (/dev/inp ut/event3)
[ 33.642] () ADS7846 Touchscreen: Applying InputClass “libinput touchscreen catchall”
[ 33.642] () ADS7846 Touchscreen: Applying InputClass “Touch rotation”
[ 33.643] () ADS7846 Touchscreen: Applying InputClass “calibration”
[ 33.643] (II) Using input driver ‘libinput’ for ‘ADS7846 Touchscreen’
[ 33.643] () ADS7846 Touchscreen: always reports core events
[ 33.643] () Option “Device” “/dev/input/event3”
[ 33.643] () Option “_source” “server/udev”
[ 33.643] (II) input device ‘ADS7846 Touchscreen’, /dev/input/event3 is tagge d by udev as: Touchscreen
[ 33.643] (II) input device ‘ADS7846 Touchscreen’, /dev/input/event3 is a tou ch device
[ 33.690] () Option “config_info” “udev:/sys/devices/platform/soc/fe204000. spi/spi_master/spi0/spi0.1/input/input3/event3”
[ 33.690] (II) XINPUT: Adding extended input device “ADS7846 Touchscreen” (ty pe: TOUCHSCREEN, id 9)
[ 33.690] () Option “AccelerationScheme” “none”
[ 33.690] () ADS7846 Touchscreen: (accel) selected scheme none/0
[ 33.690] () ADS7846 Touchscreen: (accel) acceleration factor: 2.000
[ 33.690] () ADS7846 Touchscreen: (accel) acceleration threshold: 4
[ 33.691] (II) input device ‘ADS7846 Touchscreen’, /dev/input/event3 is tagge d by udev as: Touchscreen
[ 33.691] (II) input device ‘ADS7846 Touchscreen’, /dev/input/event3 is a tou ch device
[ 33.691] (II) config/udev: Adding input device ADS7846 Touchscreen (/dev/inp ut/mouse1)
[ 33.691] () ADS7846 Touchscreen: Applying InputClass “calibration”
[ 33.691] (II) No input driver specified, ignoring this device.
[ 33.691] (II) This device may have been added with another device file.
