Can't play anything, or rescan my database
Hi all
I am seeking help already for some wifi issues, however I have got around ite by connecting via Ethernet.
Now I have another issue, which is that I can’t scan my library, or I think, I can’t play anything either. I just keep getting this error coming up again and again in the log
Jan 29 18:21:43 volumio volumio[xxx]: error: MPD error: The expression evaluated to a falsy value:
Jan 29 18:21:43 volumio volumio[xxx]: assert.ok(self.idling)
When I try to scan or update, nothing happens. If I try to play a web radio (which is the only thing I can access, as I can’t get any music scanned in), nothing happens.
Here’s a log! Just before I took this, I tried to rescan and update the database, and tried to play a web radio feed. none of them worked. http://logs.volumio.org/volumio/2NQKHUS.html
I don’t understand this - I have set up volumio many times on different RPI 4s, but this time, nothing is working, and reflashing hasn’t made any difference.
Volumio 3 Issues?
I solved this by starting again with the previous version of Volumio. Apparently there are issues with the latest version.
