Cannot find plugins
I saw from log, but how can be blocked only 3 endpoints from 13 when last few weeks was there? That’s Volumio servers issues. My connection is and was always without issues with speed over 600 mbps.
There has been a small dip in with the plugin server, but they are operating normal again. So it should be fine by now,
If you still have issues follow @balbuze advise.
exact! I see some services are in critical states. But @volumio is on it :wink:
TESTING REMOTE ENDPOINTS
https://google.com, 982 ms: OK
https://www.googleapis.com, 336 ms: OK
https://securetoken.googleapis.com, 457 ms: OK
https://myvolumio.firebaseio.com, 777 ms: OK
https://functions.volumio.cloud, 580 ms: OK
https://oauth-performer.dfs.volumio.org, 807 ms: OK
https://browsing-performer.dfs.volumio.org, 374 ms: OK
http://cddb.volumio.org, 870 ms: OK
https://functions.volumio.cloud, 627 ms: OK
http://pushupdates.volumio.org, 354 ms: OK
http://plugins.volumio.org, 752 ms: FAILED
https://database.volumio.cloud, 1201 ms: OK
https://radio-directory.firebaseapp.com, 139 ms: OK
WARNING!!! Some remote endpoints cannot be reached!
Failing endpoints:
http://plugins.volumio.org, 139 ms
volumio@antoozvolumio:~$ S
Plugins not showing
I expect there is nothing in your network blocking traffic?
I see that a couple of tunnels are down, reported it internally.
hi what should i do ?
Issue is resolved, you should be able to install plugins
WhatsApp Image 2026-09-21 at 10.26.26
still nothing
@marco_volumio , @Zabriskije
Any suggestion?
Hey @AntooZ,
I think we (community) do not have enough information about your system, build version, network etc, to help you effectively. We are dealing with a vague excerpt similar to a “Doctor, I sneezed - now I need prescription”.
This is the actual minimum that we, correction - I need, to start looking into problem affecting your system:
Using PI 4b
@nerd
