Can not use the CUE files
Volumio 3 Issues?
Hello, volumio friends
Sorry, my English is not good.
My volumio (3.661) does not recognize CUE files
My music is stored in NAS . about 8T (WAV +CUE, FLAC+CUE)
My volumio can scan these WAV FLAC APE.
But unable to use the CUE files to select tracks
I use foobar to play these CUE, it work!
Can you help me solve it?
no longer cue support :sleepy:
thank you ,
it is bad news ,
maby i should use back old version .
my old version volumio can not scan NAS complete. it often crash when the NAS has too much files.
mpd is very critical when it comes to cue files. If whatever is misaligned it causes crashes. Even with tinkering on the older version of mpd the issue persisted. Hence the decision to stop supporting it. It not caused by Volumio but MPD.
Hope there is an option to let user to choose enable or disable cue function, the risk of crash by user choose to take. or there is a tool to check and fix the cue file format before create database to avoid crash.
Ingenious! For so many years, they practically ignored the problem, and then simply turned off one of the most necessary functions of the system, instead of solving the problem. For some reason, the cheapest players can play these files, almost at the hardware level, but here, who knows how many years they have been writing a program, and now they are asking money for it, but there are fewer and fewer working functions. Maybe spend less time on all sorts of beautiful additions, and instead work on the necessary functions with high quality?
@Topa31, Did you even read my posting?
Yes. I read that it’s not you, it’s the MPD. But I didn’t find any mention of disabling this function on the MPD project page. Am I looking in the wrong place? May be…
Paid user here. Is there a way you can re-enable .cue support? Or at least give users the option to have buggy .cue support rather than none? Some of my favourite albums are single-file rips and having to seek manually is just medieval grade bullshit.
I can’t I am a moderator. Core problem is MPD being very strict on cue. A minor mismatch causes everything to break.
Why not use “Cuecutter” to fix this?
Everything was breaking in previous versions too and nobody got hurt. Please let me know how can I file a formal ticket about this, I need .cue support.
Thanks for the suggestion but Cuecutter only seems to support ogg and mp3, neither of which I use (all my albums are either .ape or .flac). Also I went to extreme lengths to ensure the most faithful copy of the original recording, I don’t want to throw away the integrity of my files. And also, why should I fix a problem that the devs created…
Here you can create a support ticket.
So this is why I can not use .cue files any more.
Hundreds of albums carefully ripped, now useless.
So, any chance to revert the updates that led to this?
Or try to manually document all settings, and then hunt down an old copy that works?
You can use Easy CD-DA Extractor to read .cue and split into individual files with all metadata info.
This is ridiculous and i̶n̶s̶a̶n̶e̶ frustrating, CUE support i̶s̶ should be a MUST! This player is ̶a̶l̶r̶e̶a̶d̶y̶ almost beyond complicated and now this :-1::-1::-1:
@vdrn Planning to make lots of friends here?
@vdrn
I get that you’re passionate about CUE support. But calling it ‘insane’ to not include it might be a stretch. Let’s talk features and facts, not insults.
Volumio & CUE File Support
Volumio has officially dropped support for CUE files , primarily due to MPD’s sensitivity. Improperly formatted CUE sheets can crash MPD, and the risk outweighed the benefits. If you rely on CUE for gapless playback or track indexing, consider converting them into properly tagged individual files instead.
Not stating that it will never come back, but that fully depends on MPD’s stability.
Thanks for brief explanation and I apologize for my previous impulsive reaction, really appreciate the project, it’s just that quite a few things that are no-brainer in virtually any player on virtually any platform are over complicated here. Maybe I’ll get used to it over time…
