Can not delet item in "Favorites"
I have no chance to delete all items in Favorites. The last one is always permanent…it is very strange that it even survives a complete fresh new install…
Any idea how to delete it?
Thanks.
Best.
Fabian
Is this a standard Volumio installation, or are you also using “MyVolumio”?
I am using MyVolumio.
F.
I suspect this is MyVolumio backing up your favourites. It is not obvious to me how to delete a backed up setting.
Edit: just checked on one of my installations, and I have a load of playlists that I thought I had deleted previously, so we are seeing the same behaviour here.
So for my understanding this is clearly a bug?!?
Where is the best place to report it?
Thanks for the feedback. Glad to know it’s not me :slight_smile:
Best. F.
Not so much a bug as no existing provision for it. You could raise it as a feature request, explaining why it is important.
Well, if I delete something and after this it is not deleted - how should I call it…a magical trick???
For me this is clearly a bug!
Best.
Fabian
Yep, it’s a bug and we’re working on a fix. Sorry guys
Thanks for the clarification.
Best.
Fabian
…the same with playlists …please correct this bug .
Inviato dal mio MI MAX 3 utilizzando Tapatalk
Any news on this?
Thanks.
Fabian
Is this forgotten???
Is important delete playlists and favourites songs!
Please work about
Hi
I Have the same problem with a Spotify song.
Still there in “Favorites” after delete.
I can put the same song to Favorites, then the entry is double.
And here comes the macical trick :slight_smile:
It doesn’t matter which one i delete.
The first one disapears and the second just stay there and can be played.
So, I would also be happy if it is solved :slight_smile:
And a function in myVolumio to reset the Favorites (Main and Radio) would be nice.
thx & greets
Hello. Just a friendly reminder that there seems to be a number of people waiting for the function to remove a favorite from their list.
Has this not been implemented yet?
I’ve noticed that too, cannot delete some favorite radio stations (like BBC Radio 1 which doesn’t work anymore).
This only confirms my thinking that the Volumio team is much more prioritising new features development than fixing obvious bugs. It’s been 4 years of this bug, how many new fancy features have been implemented during that time? And me and other people couldn’t still remove the damn favourites.
hello,
I just tested, and get a correct result : favorite removed from list.
What version do you use?
The latest one 3.512, premium account. I can’t remove stations which are often doubled or tripled. I can’t also add custom stations. Nothing is happening despite the message that a given station is deleted.
In logs nothing suspicious:
info: Removing uri http://opml.radiotime.com/Tune.ashx?id=s9608 from favourites
info: Saving Cloud item radio-favourites
info: CoreCommandRouter::executeOnPlugin: my_volumio , saveCloudItem
