Bluetooth Speaker Plugin
I was redirected to here. But my case might be different - I am trying to use Creative BT-W3 USB Bluetooth dongle. However, the system is not able to recognize it.
The system has recognized it as a sound card, Volumio listed that. I think to Volumio it is a USB device, bluetooth is transparent in this case.
The problem I have is that the OS does not list the USB dongle as a bluetooth device. Here is the output from ‘hcitool dev’:
Devices:
  •    hci0    E4:5F:01:CB:E0:01*
this is the built-in BT not the dongle. But the dongle is listed with ‘lsusb’:
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 007: ID 041e:3270 Creative Technology, Ltd
Bus 001 Device 002: ID 2109:3431 VIA Labs, Inc. Hub
It seems that the ‘HCI USB Bluetooth’ is not enabled in the kernel, I may have to compile a new one ?
the kernel is “5.10.92-v7l+ #1514 SMP Mon Jan 17 17:38:03 GMT 2022 armv7l GNU/Linux”
Where is the source I can download ?
thanks !
Hi @elehobica ,
I do not see the ‘upload plugin’ option though. I am using the latest 3.378-2.
thanks
lixin
Hi @lixin, as far as I confirmed with 3.378, indeed, sometimes it looks UI is not switched to Classic. In the case you’ll need to reload browser to reflect UI change.
(or see Bluetooth Speaker Plugin - #179 by elehobica to check if www directory is correctly located)
@elehobica
Indeed the UI is not changed to ‘Classic’ for some reasons. Folders are created correctly though. Need to troubleshoot more …
thanks !
I’ve ran into an issue where when I use tidal connect, audio doesn’t come out via bluetooth. Once you try using tidal connect, the only way to then get audio is to reboot. If i use the volumio app, bluetooth works. Only when doing tidal connect do things not work. Are you aware of this issue? If so, what is the fix/work around.
Thanks.
@elehobica
First of all, congrats on the plugin. I think it would be great, if volumio would support it officially as it offers many new applications to rpi-volumio projects.
I am currently trying to set up a “spotify-tablet” for my son (6 years old) using a rpi3 with touch display. I want to give him the possibility to discover music in spotify without giving him a smartphone or a real tablet.
First, I was using volumio3, which worked just fine with an JBL Flip 6 (after I switched to 5GHz Wlan to reduce interferences with BT). But unfortunately, there is currently no solution for a virtual keyboard on volumio3. As a virtual keyboard is essential to my project, I am trying with volumio 2.917 and the old files from here: bluetooth-speaker-plugin #149
Pairing works, but the sound is super choppy. I am testing with a local .wav and .mp3 from the SD card.
What is interesting: With the aplay command, I can play those files from the bluetooth speaker in perfect quality. But as soon as I use volumio for the same files, the playback is super choppy.
I tried installing it multiple times with a fresh installation. I also connected a separate speaker to the headphones jack on rpi and while playback on bt speaker is choppy, the playback on the wired speaker is fine.
Do you have any ideal, why the plugin works for me with volumio3 but not with volumio2. I would really appreciate any help.
Thanks a lot!
Edit: I just tried with an old “Bose Color SoundLink” Speaker. This one works fine, so maybe it is some issue with a new bluetooth version/profile. Any ideas?
Update:
  • I realized that playback with volumio3 and latest version of this plugin is actually a lot better on my JBL Flip 6 compared to volumio2 (version from #149). But still, depending on the source (podcast, local, spotify), playback on JBL Flip 6 was a bit choppy, while the old Bose Color SoundLink worked flawless.
  • I was able to solve this issue for volumio3 by updating to the latest bluez-alsa. To do so, one has to change only two lines in the file “install.sh” inside “bluetooth-controller.zip”
old: git clone -b v3.1.0 https://github.com/Arkq/bluez-alsa.git
new: git clone -b v4.0.0 https://github.com/Arkq/bluez-alsa.git
old: ExecStart=/usr/bin/bluealsa --a2dp-force-audio-cd
new: ExecStart=/usr/bin/bluealsa --profile=a2dp-source
Now playback on the new device JBL Flip 6 is perfectly clear.
Installed the Bluetooth Speaker Plugin and things seem to work OK on the latest Volumio version on both Pi Zero and Pi3 B+. However I have noticed that after installation the Shutdown function does not work anymore… After cicking the tab I am expecting to have a choice of shutdown or reboot, however nothing happens and music keeps on playing. Any suggestion anyone???
Edit: Just found out that the described issue is only true in the Classic menu. Swiching to Contemporary makes the shutdown button active again. (why???)
Hello. Please describe in more detail the entire installation process for the latest version of Volumio. For example, I did not find the folders indicated at the beginning to transfer the files unzipped from the UI, and I did not understand where to unzip the second file… I understand that you don’t want to paint this, but I have no doubt that a large number of amateurs like me will be immensely grateful to you for this work.
I found it in 162 messages. It is necessary to somehow display such messages in the header.
I’m struggling a bit with getting this running. I’ve followed the instructions above, but I’m unable to change the IO to Classic, either from the web UI or the app. I’ve double checked the folders and ru through the steps again, but no luck.
Is there something I’m likely doing wrong, or does this no longer work on the latest version?
Hi, I want to add this plugin … are the files still up to date or rather what download link is valid for the latest Volumio ?
I got this version bluetooth-speaker-plugin #165 to work with version 3.569 on Raspberry Pi Zero 2 W with a few tweaks.
I was not able to able install with “Upload Plugin”, so I copied and unzipped the bluetooth_controller.zip similarly as the other zips.
scp bluetooth_controller.zip volumio@volumio:~/
ssh volumio@volumio
mkdir bluetooth_controller && cd bluetooth_controller
miniunzip ~/bluetooth_controller.zip
And then installed with (make sure you are in the directory where you unzipped the plugin)
volumio plugin install
I also applied these changes before installing: bluetooth-speaker-plugin #190
At first the bluetooth playback was stuttering a lot, but I got it fixed with these changes to bluetooth parameters: Raspberry Pi Zero 2 W - Stuttering sound over Bluetooth
It seems that I have successfully installed Bluetooth plugin with your advices thanks.
But in web interface I don’t have Bluetooth devices in output device.
In ssh → bluetoothctl, I see my device as paired.
When I play the song I have no sound.
thx for your help
Unfortunately I can’t get this plugin to work on PI Zero 2 W - I had to do it over ssh and it hangs at 70%. I gave it a whole day to install, but after a few hours I gave up.
Progress: 70
Status :Instalowanie niezbędnych narzędzi
make[1]: Leaving directory ‘/tmp/bluez-alsa/build’’
My Volumio version is 3.703
I’m having the same issue. I’m not getting Bluetooth for an output device. I can also see my connected speaker in bluetoothctl
System Version: 3.742
PSA: You will not be able to uninstall this plugin if it doesn’t work
Hi friend, I’am thinking to realize a volumio streamer with Rapsberry PI4 4gb, I absolutely need of working BT. A the moment Volumio has released 3.785-2024-12-16-pi ver. Do you know if the procedure is working on last release? Could anyone help me ?
Chhers
Hello Work for me on PI 3 for this version of volumio
Does anyone have any way to play music via bluetooth or wifi(jbl wifi)?
This is about using volumio as a wi-fi streamer…
I have Volumio premium
It works for me to play radio stations, but I can not get it to work with spotify. Any tips here?
