Automatic Start // Webradio
I have an Raspberry Pi with the current version of Volumio (3.616).
I’m playing an internet radio from an URL “http://…/v1026.mp3”
With the AutoPlay Plugin the radio starts automatically after rebooting the Raspberry pi.
But my issue is the following:
The radio stream itself stops at 19:30. That is fine and as planned.
On the next day the radio stream starts casting again at 05:00
But Raspberry pi is not starting to play automatically.
Is there a way to let the Raspberry pi play the radio stream automatically?
BR, Mario
Without a reboot, no.
When the stream is dead Volumio will stop polling the stream. so when it starts again after x hours, Volumio is not aware of this.
You can create a workarround with a crontab, to reboot the rpi at 05:01.
See:
Thank you very much! The cronjob solved my issue. :slight_smile:
BR, Mario
Autostart works fine; the radio now starts playing as soon as the Pi boots. It starts in the morning via a timer, and I turn it off manually. It’s a shame I didn’t discover this plugin sooner.
Hi - is the AutoPlay Plugin still available? I cant see it under the lists of available plugins.
And - can I assign pushbuttons via the GPIO to select from a handful of radio stations?
It’s still there
We have a magic button on this forum, you press it, you ask it et voila answers. It’s called search.
