Artwork One: a new interface for Volumio OS (work in progress)
Hi everyone,
Volumio builds beautiful devices, and the platform underneath is excellent. The
interface that ships with Volumio OS, though, looks dated next to the hardware it
runs on. That is what inspired me to build a new one.
Artwork One turns the record into the interface: the cover fills the screen,
softly blurred, the controls float above it on frosted glass, and the colours are
sampled from the artwork, so the whole interface changes mood with every album.
It is around 90 percent done and I use it daily. Tell me what you think, and what you
would want from an interface like this.
Source, screenshots and details: GitHub - michaltamas/volumio-artwork-theme: Artwork One: a Volumio web interface theme where the album artwork becomes the interface — blurred cover backgrounds, frosted-glass controls and colours sampled from the cover · GitHub
Great. That’s the one I want.
Woah, intriguing project you got here and I really like the design!
I just downloaded it to my setup (4.119 on RPi 4). Installation worked flawlessly and really love the design but I did notice some things when playing around:
1. Playback path is displayed incorrectly
I use Allo Piano 2.1 in Dual Mono mode with resampling to 32bit which is displayed correctly at the playback settings. On the playback screen however following is displayed:
2. Missing volume bar on playback screen
I’d definitely like to see a volume bar here. It’s shown on the library view but not here. Feels a bit inconsistent and cumbersome if you want to change it quickly.
3. Via mobile phone (iPhone 16, Safari): Volumio Crash on volume change
This is more critical. When changing the volume from the playback screen Volumio crashes and reloads. The volume cannot be changed. See logs below.
Sep 13 13:42:14 volumio volumio[3773]: |||||||||||||||||||||||| WARNING: FATAL ERROR |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Sep 13 13:42:14 volumio volumio[3773]: TypeError: Cannot read properties of undefined (reading 'then')
Sep 13 13:42:14 volumio volumio[3773]:     at Socket.<anonymous> (/volumio/app/plugins/user_interface/websocket/index.js:826:20)
Sep 13 13:42:14 volumio volumio[3773]:     at Socket.emit (node:events:514:28)
Sep 13 13:42:14 volumio volumio[3773]:     at /volumio/node_modules/socket.io/lib/socket.js:503:12
Sep 13 13:42:14 volumio volumio[3773]:     at process.processTicksAndRejections (node:internal/process/task_queues:77:11)
Sep 13 13:42:14 volumio volumio[3773]: |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Sep 13 13:42:15 volumio sudo[5032]:  volumio : PWD=/ ; USER=root ; COMMAND=/bin/journalctl '--since=2026-09-13 13:41'
Sep 13 13:42:15 volumio sudo[5032]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=1000)
Sep 13 13:42:15 volumio sudo[5032]: pam_unix(sudo:session): session closed for user root
Sep 13 13:42:15 volumio volumio-remote-updater[823]: [2026-09-13 13:42:15] [error] handle_read_frame error: websocketpp.transport:7 (End of File)
Sep 13 13:42:15 volumio volumio-remote-updater[823]: [2026-09-13 13:42:15] [disconnect] Disconnect close local:[1006,End of File] remote:[1006]
Sep 13 13:42:15 volumio volumio5-onboarding[1516]: time=2026-09-13T13:42:15.106+02:00 level=ERROR msg="failed reading message" error="websocket: close 1006 (abnormal closure): unexpected EOF"
Sep 13 13:42:15 volumio systemd[1]: volumio.service: Main process exited, code=exited, status=1/FAILURE
Sep 13 13:42:15 volumio volumio5-onboarding[1516]: time=2026-09-13T13:42:15.113+02:00 level=WARN msg="reconnection attempt failed" error="dial tcp 127.0.0.1:3000: connect: connection refused"
Sep 13 13:42:15 volumio systemd[1]: volumio.service: Failed with result 'exit-code'.
Sep 13 13:42:15 volumio systemd[1]: volumio.service: Consumed 51.844s CPU time.
Sep 13 13:42:15 volumio systemd[1]: Started dynamicswap.service - dynamicswap service.
Sep 13 13:42:15 volumio systemd[1]: dynamicswap.service: Deactivated successfully.
Sep 13 13:42:15 volumio systemd[1]: volumio.service: Scheduled restart job, restart counter is at 3.
Sep 13 13:42:15 volumio systemd[1]: Stopped volumio.service - Volumio Backend Module.
Sep 13 13:42:15 volumio systemd[1]: Started volumio.service - Volumio Backend Module.
Sep 13 13:42:16 volumio volumio5-onboarding[1516]: time=2026-09-13T13:42:16.115+02:00 level=WARN msg="reconnection attempt failed" error="dial tcp 127.0.0.1:3000: connect: connection refused"
Sep 13 13:42:16 volumio volumio[5045]: info: -------------------------------------------
Sep 13 13:42:16 volumio volumio[5045]: info: -----            Volumio3              ----
Sep 13 13:42:16 volumio volumio[5045]: info: -----          System startup          ----
4. Via mobile phone (iPhone 16, Safari): Can’t escape volume overlay from Home Screen
Volume can be successfully changed from the home screen without the system crashing. However I can’t return from this overlay and need to reload the page in order to escape it.
Looking forward to further updates!
Thank you, this is exactly the kind of report one hopes for, and the log made the crash
easy to find. All four are fixed in v1.3.0.
1. Playback path. It had No resample hard-coded and the Bit perfect badge always
lit, neither of which asked the player anything. Both now read your real playback
settings, so with resampling to 32 bit it reads SOURCE 24/48 → RESAMPLE 32 → <your DAC>
and the badge stays off. Please confirm on your setup, I cannot test an Allo Piano 2.1.
2. Volume on the playback screen. Added, in the header. On phones the speaker button
opens the Zones & Outputs sheet, which carries the volume.
3. The crash. Your log pointed straight at it: the Zones page sent this player’s own
volume as a multiroom command, which a player without the multiroom plugin cannot answer,
so the backend died. It now uses the plain volume command.
4. Trapped in the overlay. That sheet was unstyled Volumio markup covering the whole
screen. It is a bottom sheet now: tap outside or pull it down by the handle to close. The
speaker icon mutes, and the volume slider no longer jumps while you drag it.
Your screenshots also showed the sheet blurred on iOS Safari, fixed as well.
Update and reload the page:
curl -fsSL https://raw.githubusercontent.com/michaltamas/volumio-artwork-theme/master/scripts/install.sh | bash
That was quick! Just had a brief test.
Issue #1: Unfortunately still not showing the correct audio path:
Let me know if I can do anything to diagnose.
Issue #2: Looks good. Could be a bit larger on the header as fine control is difficult but I understand if that’s a design decision.
Issue #3: Solved.
Issue #4: Solved.
New Issues:
Issue #5: Indicator jumps back to preset value at volume overlay
I have the default start up volume set to 20%. When changing the volume on the overlay the volume changes but the indicator will jump back to 20% after 1-2 seconds (actual volume remains on the set value though, so just a display issue). Happens both on mobile and desktop browser.
Thank you, you are making a great tester. All five are fixed now, and sorry for the
regression along the way: the path was reading the wrong field on players with an I2S
DAC, which is exactly the kind of thing I would never have caught on my own hardware.
I hope it behaves from here. If you run into anything else, or have ideas for
improvements, keep them coming: I am happy to work them in. In the meantime I will carry
on polishing the rest of the interface.
Hi @Michal_Tamas. This is AWESOME, and off to a great start. Congratulations! What are the next steps, once fully polished, for it to be UI alternative that can be selected from the Plugins or UI section within Volumio?
All issues solved, looks great!
I won’t have the possibility to test for the next three weeks but certainly will pick up again after that. For now it looks fantastic, great work!
Until now every screen carried its own header. Different top spacing, some sticky and some not, only some blurring what scrolled beneath them — small things, but together they made the interface feel like several apps. They now share one component: the trail, the search and the controls sit on the same line everywhere, stay put while you scroll, and the page dissolves softly behind them.
Along the way the volume moved to the bottom right of Now Playing, beside what plays next; on a phone the filter rests as a magnifier and slides open on a tap, so the header keeps to a single line; and the Zones volume finally looks like every other volume in the theme.
Plus a round of fixes from testing: the equaliser bars stand still when the player does, the elapsed time can no longer run past the end of a track, and the album page no longer draws a dark band across half the screen.
:point_right: Release Artwork One v1.5.1 · michaltamas/volumio-artwork-theme · GitHub
Enjoy the three weeks away, and ping me whenever you are back at the player. Your testing is the reason the last four releases exist. :wink:
Thank you! Right now the installer registers the theme in Volumio’s own third-party UI list, so after installing you pick it in Settings → System → User Interface layout design. It survives updates, and you can switch back to Contemporary at any time from the same place.
The next step is the official route: packaging it as a User Interface plugin — a plugin that calls registerThirdPartyUI on install, which is what makes a UI appear in the Plugins section and installable in one click. That means submitting it to the plugin store for review, so I want the polish finished first: a few screens still have their own header, and I would rather ship that as one consistent thing than half of it.
So: a plugin, yes — once the last rough edges are gone. Watch the releases, it is not far off.
I love it, works a treat as far as i can tell. Thank you for the great work!
Now if only i could get to it and skin now playing to match :joy:
*pi5/8g - 8.8"ws lcd
Thank you very much for the kind words! :blush: I really appreciate it. If you notice anything that could be improved or come across any bugs, I’d be very grateful for any feedback. It will help me fine-tune everything and make it even better. :pray:
This is awesome, thank you very much. Your work is much appreciated.
Artwork One 1.6 - now in daylight
Some rooms are dark. Some records are not. Artwork One now comes in a light theme: the same cover-led design, only on warm paper instead of black - white glass, ink type, shadows that feel like daylight instead of a screen.
Switch between Dark, Light and System in Settings → Appearance. The choice lives on each device, so the phone on the sofa can be light while the screen in the rack stays dark.
I noticed the @volumio team has been busy on the same thing as this thread: Introducing Nova. Their new Nova theme looks stunning - congrats to @leorigna and the team, great to see the UI get this kind of love.
Hi Michal,
Even though the Volumio team came up with the new theme I hope for Artwork One to continue its journey since its available for non-premium users unlike Nova!
Thanks for your work!
Hey Michal, thank you very much for your work — the Artwork One interface is fantastic. I have a small problem: I can’t switch back to the dark theme on the display connected via HDMI. Changing the theme in the browser doesn’t change the theme on the HDMI display. Thanks for your help.
Thanks Elvis for the report. That was a bug :frowning: , fixed in 1.6.2. The theme choice is saved per browser, and the HDMI display is a browser of its own (Volumio’s kiosk), which has no dark mode and so fell back to light. The default is dark again now: update the theme and the display goes back to dark by itself, nothing to switch. If you ever want it light there, add ?theme=light to the address the display opens.
Thanks for the quick fix. In version 1.6.2, the theme is dark (on the HDMI screen).
