An error occurred while playing the current track
I’m getting this error while playing through Qobuz connect. I don’t get it when I hook up my Wiim Ultra. It’s not the connection or cables. I’ve done a factory reset. Installed current update, plugged and unplugged everything. Very frustrating that I’m having issues with a $1,500 player while the cheap Wiim just works. I’ve sent this unit back to Volumio in the past for a different reason. Maybe it is just a bad unit. Any recommendations?
That must be frustrating. You have access to free support from Volumio.
To get help in the forum, you need to provide way more detail about your issue and system.
Please create a support ticket with Volumio.
The community has no access to the resource of Volumio hardware, which are needed to provide proper support.
