AirPlay Volumio
Volumio 3 Issues?
hello, I’m new, I have free volumio on Rpi4 with allo boss 1.2. I have a problem because airplay interrupts me terribly - both when I play from YouTube and Tidal. should I set something?
have you installed FusionDSP? If so, please disable it and test again.
and then will I be able to reinstall eq?
no there are some issues with DSP, see also:
To test, you don’t have to remove the plugin but just disable it.
I turned off DSP and airplay works. do you know how to fix it or is there another equalizer plugin?
No there is no other EQ plugin.
We are working to try to fix this issue… We’ll let you know when something is available…
do you know when it will be possible to fix it - within a month or, for example, a year?
volumio is extra, but if it doesn’t work, I’ll probably have to run moode audio
Today I installed volumio again and a new dsp - nothing has changed, it still freezes - you can’t use it - software failure. everything works perfectly in moode audio. but I would like to use volumio
Did you manage to solve the problem of sound stuttering and long delay when fusion dsp is running? I’m sending thanks via airplay?.
I have this problem all the time.
Volumio 3 Issues?
Hi. Do we know if this issue will be fixed? thanks!
I just wanted to confirm that this problem still exists in the latest versions of Volumio (4.119) and FusionDSP (2.0.79). AirPlay reception works perfectly with the DSP disabled, but the music stutters and pauses continuously when DSP is enabled. I love FusionDSP because of its headphone-based EQ’s - I have a few pairs that are basically unusable without EQ -so- I really can’t run with Fusion disabled. My fix is to use Volumio with UPnP PlayTo (via upmpdcli, which works fine) but this limits my choice of source application. Hoping for some progress that makes Fusion and AirPlay work well together.
