pbat13
February 16, 2023, 12:52pm
1
A feature to enable “Play” if a BBC Sounds On-Demand URL is pasted into the Web Radio in Volumio.
Could a BBC Sounds ON-DEMAND URL address be pasted as a Web Radio if the “Play” button in the URL in the BBC Sounds is activated by Volumio ?
Also a seek bar and possibly a tracklist as the Sounds URL would show.
Installing and configuring LMS is a huge pain. Alternatively a fully functional BBC Sounds plugin.
dvo
February 16, 2023, 1:22pm
2
hi pbat13,
bbc sounds is only for the people of the UK we can’t listen to it.
so testing it is not possible from outside the UK
Hi all,
I listen to BBC Radio 6 Music pretty constantly and usually use my Raspberry Pi running Volumio with Web Radio. Put it on today and had a message play over the top of the stream telling me they were ending support for this device.
It seems to be a common theme for the BBC forcing you to use their App. The cynic in me assumes this is purely so they can data mine everyone.
Further info from the beeb here: Why do I hear a message on my internet radio stating that BBC Radio will stop work…
pbat13
February 16, 2023, 2:01pm
3
Hi DVO
Is there a “generic” way to to play on-demand services ? ie there must be similar on-demand web or browser based service in your and other parts of the world. When I play an on-demand show from BBC Sounds the browser player seems like a Radio URL except with a play button. I have a live stream URL for many BBC radio stations but they are obviously live. I am not a coder or web expert but I would have thought that using an on-demand URL in the volumio web radio would simply require the “play” activation - whether in BBC Sounds or other similar on-demand providers ?
thank you
dvo
February 16, 2023, 2:06pm
4
under my web radio’s you could add it ( the 3 dots at the end ),
if your in the UK but outside stream will be lower quality.
what stream of sounds do you want.
pbat13
February 16, 2023, 2:14pm
5
i have tryed pasting a Sounds on-demand URL into the web radio and volumio returns a error - eg Radio 2 In Concert - Elton John In Concert (2001) - BBC Sounds . Apparently BBC Sounds is available in other countries via a browser How do I use BBC Sounds if I live outside the UK? | BBC Sounds .
When the above link or similar is opened in a browser the page has a play button and seek bar - could that type of page or stream be made compatible with the my web radio ?
thanks
dvo
February 16, 2023, 2:33pm
6
that’s not the stream url you have to paste i’m still searching to find one
the url is coded so don’t find it on the page.
i don’t think so it plays only on the site or with iplayer inside of the UK
but you can try :
https://www.hendrikjansen.nl/henk/streaming2.html#bbc
pbat13
February 16, 2023, 2:59pm
7
the link is for live streams - as i said, i have live stream urls. the elton john link is on-demand.
pbat13
February 16, 2023, 3:01pm
8
if the stream is able to be activated within a web browser then could the same be done within my web radio ?
dvo
February 16, 2023, 3:02pm
9
no, this is not true normal streams yes you could add but not the dash encoded one’s.
pbat13
February 16, 2023, 3:06pm
10
these are the live urls i have - BBC AAC Radio Streams – Astra 2 .
by activated i mean using the “play” button.
dvo
February 16, 2023, 3:08pm
11
they will play till mid 2023 after that there gone.
Similar discussion on in this thread, since BBC will again make changes.
I’m running Volumio 3.251 on a Raspberry Pi.
I use it a lot for streaming radio. I live in the UK so stream BBC (British Broadcasting Corporation) radio a lot. Yesterday I was listening to BBC Radio 4 when the stream was interrupted (by the BBC) to say that the stream I was listening to would be discontinued this year. If I was listening via a smart speaker or other device I should contact the manufacturer. Or alternately I could listen through the BBC Sounds app.
Doe anyone know anythin…
pbat13
February 16, 2023, 3:12pm
13
does the my web radio require a dash decoder then ? dash is open source according to bbc website
pbat13
February 16, 2023, 3:20pm
14
the discontinuation of streams mid 2023 seems to affect SHOUTcast devices - BBC Sounds Stop Working in 2023? Everything You Need to… | Radio.co
pbat13
February 16, 2023, 3:25pm
15
HLS streams will still be available
Wheaten
February 16, 2023, 3:34pm
17
The “ondemand” are no streams, so you won’t be able to use it as a radio stream.
It’s being played in a container. Volumio is not a web browser and doesn’t has this features.
I even doubt if you install “touch display” (on local display connected to the Volumio device) with the chromium browser, it will work.
But you can test it yourself. Just open a new browser (press ALT+HOME), enter the url and see how it goes.
dvo
February 16, 2023, 3:44pm
19
your option worked with
big ALT + HOME
and then the bbc sounds
to return to volumio
big ALT + FN +F4 or big ALT + F4
listening to bb king on sounds…
you need a screen and pref. keyboard and mouse
Wheaten
February 16, 2023, 3:48pm
20
