Volumio 3 Issues?
Just a quick question, I have a nice Volumio box with a 14 inch display and I wanted to put a led on the front panel that shows activity… Ive seen where you can add a led to a pi with out a hat but no instructions on adding one with a hat… can this be done?. I have a Rasberry PI 3b and a hifiberry dac hat pro . Thanks in advance.
HIFIBERRY DAC+, DAC+ ADC, DIGI+ AND AMP+, DAC2 PRO
GPIO2-3 (pins 3 and 5) are used by our products for configuration. If you are experienced with I2C, you might add other slave devices. If you a a novice, we don’t recommend this at all.
GPIOs 18-21 (pins 12, 35, 38 and 40) are used for the sound interface. You can’t use them for any other purpose.
On the HiFiBerry Digi+, GPIO16 is also reserved.
On the HiFiBerry Digi+ Pro GPIOs 5 and 6 are also used and cannot be used for anything else.
Okay in doing research it looks like GPIO 27 would be safe to use for the activity led…
I understand I have to edit the config.
As far as the ground.can I use any of the ground pins?
Thanks for your help…
