Volumio is great.
v3 and Tidal Connect is working (almost) perfectly for me.
So far no dropouts, and not one ‘spinning circle of death’!
The only problem: Accented characters are not being displayed on the now playing screen.
They are just skipped.
I had this same problem with v2, but was hoping v3 would fix it.
Any advice?
Or at least you guys admitting it’s a bug?
Thanks!
Edit: I’m using the “contemporary” local display plugin, if that matters.
