I installed the touch display plugin but the screen is still black. Nothing happens. There is only a green light on the backpanel of the screen that blinks.
Can somebody help me to get this display work?
In the past i tested 4.3“ and 5“ DSI displays from Waveshare. They worked out of the box.
config.txt and volumioconfig.txt are owned by Volumio. Every change you make in them will be lost during an update.
All user specific entries should go to userconfig.txt. This will remain even after an OTA.
If you run the same screen as me, what you stated, The screen works out of the box with V3.757. I haven’t modified or added anything. This is just the first boot. (rpi4)
That is nice. I know it from the 4,3“ DSI and the 5“ DSI. They also work out of the box.
But i think my 2.8 DSI is broken. There is no bootscreen or something. I ordered a one it will arrive at wednesday.
