Hi, after the last upgrade to 2.378 version, when I select YouTube the following 3 messages appear:
! Browse error - An error occurred while browsing the folder (in red, but what folder ?)
Volumio has no permissions - Grant Volumio access to your TouTube account to access your playlist (in blue)
YouTube - Fetching data from Youtube. This may take some time (in blue)
I put a string in the search box and the I received the last message again.
I waited, but nothing happened … I tried to update the plugin and to re-enable it, without results.
How can I authorize the access ? Before I didn’t do anything and all worked very well.
Or the problem is another?
Since I received too many answers and advice… so I tried to do it myself.
I disabled the plugin
I enabled it again and the displayed code in the Account Setting changed
from the web interface I clicked on the link: google.com/device (without steps 1 & 2 I got “Code error”)
I entered the new displayed code and authorized the device on my Google account
Now it finds and plays music and does not return the initial " Browse error " anymore.
But I don’t remember doing this in the past when I upgraded the system to a new version.
It seems the code has to be really “fresh” to be accepted by Google / Youtube.
This is the reaseon why one has to disable/enable the plugin to get a new one.
Would be interesting for how long one can wait to register it until the “wrong code. please retry” message appears when trying to register the device.
I used an older version of Volumio and as of April 2019, there has been a change in the way Youtube handles these requests regardless of version used, what you do to login and register your device
Unfortunately I also tried to install Volumio2 again. It works everything except the youtube plugin.
does not give me the google device authorization code.
Does it work for you?
Hi all,
I have the same problem.
No code displayed in the plugin so impossible to fill in the device google page, and to get an access granted for YouTube
