YouTube Plugin Code NOT generating
I have been using Youtube plugin and it was working perfectly working in version 2.668.
Recently I upgrade to version 2.673.
I am not able to get the Code generated for YouTube Plugin. It is BLANK.
I revert to the old version but now it is also NOT showing the code. It is BLANK
I am using the free version of the Volumio.
I tried this with my Volumio Login and without Volumio Login also. It is the same.
I tried reinstalling the plugin multiple times also, still in vain.
I am using RPi 3B+
Any inputs on solving this problem will be apprecaited OR do we need to wait for another update on the Volumio version.
Thanks,
Tiken M
i face the same problem too
I am also facing this problem.
Seems no way to get Volumio to generate the code. Uninstall / reinstall plugin and update to latest Volumio 2.692, does not help. I’m signed in etc.
Please refer to my reply here:
https://forum.volumio.org/youtube-plugin-not-showing-the-code-plugin-settings-t13506-10.html
