Hi guys!
Will the NX-N500’s asynchronous USB dac be compatible with the Raspberry Pi 3 B+ using Volumio?
The specs are -
DSD 2.8 MHz / 5.6 MHz
FLAC / WAV / AIFF 384 kHz / 32-bit
Apple Lossless 96 kHz / 24-bit playback
ESS 32-bit D/A converter
From Marketing material -
USB-DAC Function
The NX-N500 has a high performance USB DAC that supports PCM 384 kHz / 32-bit and DSD 5.6 MHz native resolutions. It is compatible with asynchronous transmission and produces low-jitter by using its own master clock versus using the clock in the PC. It also makes use of an ASIO driver that achieves lower latency and higher throughput.
Will this DAC work with Volumio on a standard Raspberry Pi 3 B+ board via one of its USB ports?
Thanks in advance!
