HI - I am trying to replace the blank screen with an image. Installed xscreensaver but it does not show as a plugin and I can not set it up.
Does xscreensaver work with Volumio?
If so, how do I set it?
It’s impossible to answer your question, with this less details.
- On which device are you running Volumio? (rPi, x86,…)
- What kind of screen is attached?
- Which version of Volumio are you using? (don’t say the latest)
You are correct - my bad:
- RPI 4B
- Standard LED computer screen (Samsung 21")
- Volumio Ver 3.512 (Sun 25 Jun)
- Restore Volumio by doing a factory reset
- Perform all configurations
- Reboot
- Install “Touch Display” plugin. This plugin has a setting for a screen saver (Screen will turn black)
If you want t have pictures, you can install “Playing now” plugin.
- Disable the screen saver in the “Touch display” plugin
- Configure “Playing now”
This plugin can load random pictures when Volumio is not playing.
Sounds good - will give it a try this evening.
Thank you!
4 posts were merged into an existing topic: [PLUGIN] Now Playing
