I have built a USB dac around an xmos xu208 USB module. But the problem is that there is a bug, because when i set volumio 3 in dsd over pcm, i hear a White noise. When i set up the remonstering on native (1bit) en 384khz, also pcm, it plays. Could you update the drivers in volumio? Thanks by advance.
BTW, my other topping dacs based on de xmos xu208 had the same issue.
