If you can spot what may be wrong. This is the latest github download. Running it as root.
Error in GnuTLS initialization: Failed to acquire random data.
converted 'http://repo.volumio.org/Packages/Upmpdcli/x86/libupnp6_1.6.20.jfd5-1_i386.deb' (ANSI_X3.4-1968) -> 'http://repo.volumio.org/Packages/Upmpdcli/x86/libupnp6_1.6.20.jfd5-1_i386.deb' (UTF-8)
--2017-03-17 04:14:35-- http://repo.volumio.org/Packages/Upmpdcli/x86/libupnp6_1.6.20.jfd5-1_i386.deb
Resolving repo.volumio.org (repo.volumio.org)... 80.69.77.195
Connecting to repo.volumio.org (repo.volumio.org)|80.69.77.195|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 174424 (170K) [application/octet-stream]
Saving to: 'libupnp6_1.6.20.jfd5-1_i386.deb'
libupnp6_1.6.20.jfd5-1_i386.deb 100%[============================================================>] 170.34K 95.8KB/s in 1.8s
2017-03-17 04:14:37 (95.8 KB/s) - 'libupnp6_1.6.20.jfd5-1_i386.deb' saved [174424/174424]
converted 'http://repo.volumio.org/Packages/Upmpdcli/x86/libupnpp3_0.15.1-1_i386.deb' (ANSI_X3.4-1968) -> 'http://repo.volumio.org/Packages/Upmpdcli/x86/libupnpp3_0.15.1-1_i386.deb' (UTF-8)
--2017-03-17 04:14:37-- http://repo.volumio.org/Packages/Upmpdcli/x86/libupnpp3_0.15.1-1_i386.deb
Length: 242414 (237K) [application/octet-stream]
Saving to: 'libupnpp3_0.15.1-1_i386.deb'
libupnpp3_0.15.1-1_i386.deb 100%[============================================================>] 236.73K 70.0KB/s in 3.4s
2017-03-17 04:14:40 (70.0 KB/s) - 'libupnpp3_0.15.1-1_i386.deb' saved [242414/242414]
Selecting previously unselected package libupnpp3.
(Reading database ... 30921 files and directories currently installed.)
Preparing to unpack libupnpp3_0.15.1-1_i386.deb ...
Unpacking libupnpp3 (0.15.1-1) ...
Setting up libupnpp3 (0.15.1-1) ...
Processing triggers for libc-bin (2.19-18+deb8u7) ...
(Reading database ... 30927 files and directories currently installed.)
Preparing to unpack libupnp6_1.6.20.jfd5-1_i386.deb ...
Unpacking libupnp6 (1:1.6.20.jfd5-1) over (1:1.6.19+git20141001-1+deb8u1) ...
Setting up libupnp6 (1:1.6.20.jfd5-1) ...
Selecting previously unselected package upmpdcli.
Preparing to unpack upmpdcli_1.2.12-1_i386.deb ...
Unpacking upmpdcli (1.2.12-1) ...
Setting up upmpdcli (1.2.12-1) ...
Failed to read /proc/cmdline. Ignoring: No such file or directory
invoke-rc.d: policy-rc.d denied execution of start.
Processing triggers for systemd (215-17+deb8u6) ...
Installing Shairport-Sync
converted 'http://repo.volumio.org/Volumio2/Binaries/x86/shairport-sync_2.8.4-1_i386.deb' (ANSI_X3.4-1968) -> 'http://repo.volumio.org/Volumio2/Binaries/x86/shairport-sync_2.8.4-1_i386.deb' (UTF-8)
--2017-03-17 04:14:42-- http://repo.volumio.org/Volumio2/Binaries/x86/shairport-sync_2.8.4-1_i386.deb
Length: 114986 (112K) [application/octet-stream]
Saving to: 'shairport-sync_2.8.4-1_i386.deb'
shairport-sync_2.8.4-1_i386.deb 100%[============================================================>] 112.29K 475KB/s in 0.2s
2017-03-17 04:14:47 (475 KB/s) - 'shairport-sync_2.8.4-1_i386.deb' saved [114986/114986]
converted 'http://repo.volumio.org/Volumio2/Binaries/x86/libssl1.0.2_1.0.2h-1_i386.deb' (ANSI_X3.4-1968) -> 'http://repo.volumio.org/Volumio2/Binaries/x86/libssl1.0.2_1.0.2h-1_i386.deb' (UTF-8)
--2017-03-17 04:14:47-- http://repo.volumio.org/Volumio2/Binaries/x86/libssl1.0.2_1.0.2h-1_i386.deb
Length: 1718652 (1.6M) [application/octet-stream]
Saving to: 'libssl1.0.2_1.0.2h-1_i386.deb'
libssl1.0.2_1.0.2h-1_i386.deb 100%[============================================================>] 1.64M 57.2KB/s in 18s
2017-03-17 04:15:07 (92.1 KB/s) - 'libssl1.0.2_1.0.2h-1_i386.deb' saved [1718652/1718652]
Selecting previously unselected package libssl1.0.2:i386.
(Reading database ... 30980 files and directories currently installed.)
Preparing to unpack libssl1.0.2_1.0.2h-1_i386.deb ...
Unpacking libssl1.0.2:i386 (1.0.2h-1) ...
Setting up libssl1.0.2:i386 (1.0.2h-1) ...
Selecting previously unselected package shairport-sync.
(Reading database ... 31002 files and directories currently installed.)
Preparing to unpack shairport-sync_2.8.4-1_i386.deb ...
Unpacking shairport-sync (2.8.4-1) ...
Setting up shairport-sync (2.8.4-1) ...
Adding user `shairport-sync' to group `audio' ...
Adding user shairport-sync to group audio
Done.
Processing triggers for man-db (2.7.0.2-5) ...
Installing LINN Songcast module
converted 'http://repo.volumio.org/Packages/Upmpdcli/x86/sc2mpd_1.1.1-1_i386.deb' (ANSI_X3.4-1968) -> 'http://repo.volumio.org/Packages/Upmpdcli/x86/sc2mpd_1.1.1-1_i386.deb' (UTF-8)
--2017-03-17 04:15:08-- http://repo.volumio.org/Packages/Upmpdcli/x86/sc2mpd_1.1.1-1_i386.deb
Length: 977414 (955K) [application/octet-stream]
Saving to: 'sc2mpd_1.1.1-1_i386.deb'
sc2mpd_1.1.1-1_i386.deb 100%[============================================================>] 954.51K 90.1KB/s in 14s
2017-03-17 04:15:22 (67.5 KB/s) - 'sc2mpd_1.1.1-1_i386.deb' saved [977414/977414]
Selecting previously unselected package sc2mpd.
(Reading database ... 31018 files and directories currently installed.)
Preparing to unpack sc2mpd_1.1.1-1_i386.deb ...
Unpacking sc2mpd (1.1.1-1) ...
Setting up sc2mpd (1.1.1-1) ...
Volumio Init Updater
converted 'http://repo.volumio.org/Volumio2/Binaries/x86/volumio-init-updater' (ANSI_X3.4-1968) -> 'http://repo.volumio.org/Volumio2/Binaries/x86/volumio-init-updater' (UTF-8)
--2017-03-17 04:15:23-- http://repo.volumio.org/Volumio2/Binaries/x86/volumio-init-updater
Length: 6432 (6.3K) [application/octet-stream]
Saving to: '/usr/local/sbin/volumio-init-updater/volumio-init-updater'
/usr/local/sbin/volumio-init-upd 100%[============================================================>] 6.28K --.-KB/s in 0s
2017-03-17 04:15:23 (525 MB/s) - '/usr/local/sbin/volumio-init-updater/volumio-init-updater' saved [6432/6432]
Zsync
converted 'http://repo.volumio.org/Volumio2/Binaries/x86/zsync' (ANSI_X3.4-1968) -> 'http://repo.volumio.org/Volumio2/Binaries/x86/zsync' (UTF-8)
--2017-03-17 04:15:23-- http://repo.volumio.org/Volumio2/Binaries/x86/zsync
Length: 226588 (221K) [application/octet-stream]
Saving to: '/usr/bin/zsync'
/usr/bin/zsync 100%[============================================================>] 221.28K 80.6KB/s in 2.7s
2017-03-17 04:15:25 (80.6 KB/s) - '/usr/bin/zsync' saved [226588/226588]
Adding volumio-remote-updater
converted 'http://repo.volumio.org/Volumio2/Binaries/x86/volumio-remote-updater' (ANSI_X3.4-1968) -> 'http://repo.volumio.org/Volumio2/Binaries/x86/volumio-remote-updater' (UTF-8)
--2017-03-17 04:15:25-- http://repo.volumio.org/Volumio2/Binaries/x86/volumio-remote-updater
Length: 14912752 (14M) [application/octet-stream]
Saving to: '/usr/local/sbin/volumio-remote-updater'
/usr/local/sbin/volumio-remote-u 100%[============================================================>] 14.22M 145KB/s in 2m 30s
2017-03-17 04:17:56 (97.4 KB/s) - '/usr/local/sbin/volumio-remote-updater' saved [14912752/14912752]
Installing Upmpdcli Streaming Modules
converted 'http://repo.volumio.org/Packages/Upmpdcli/upmpdcli-gmusic_1.2.12-1_all.deb' (ANSI_X3.4-1968) -> 'http://repo.volumio.org/Packages/Upmpdcli/upmpdcli-gmusic_1.2.12-1_all.deb' (UTF-8)
--2017-03-17 04:17:56-- http://repo.volumio.org/Packages/Upmpdcli/upmpdcli-gmusic_1.2.12-1_all.deb
Length: 10146 (9.9K) [application/octet-stream]
Saving to: 'upmpdcli-gmusic_1.2.12-1_all.deb'
upmpdcli-gmusic_1.2.12-1_all.deb 100%[============================================================>] 9.91K --.-KB/s in 0s
2017-03-17 04:17:57 (217 MB/s) - 'upmpdcli-gmusic_1.2.12-1_all.deb' saved [10146/10146]
converted 'http://repo.volumio.org/Packages/Upmpdcli/upmpdcli-qobuz_1.2.12-1_all.deb' (ANSI_X3.4-1968) -> 'http://repo.volumio.org/Packages/Upmpdcli/upmpdcli-qobuz_1.2.12-1_all.deb' (UTF-8)
--2017-03-17 04:17:57-- http://repo.volumio.org/Packages/Upmpdcli/upmpdcli-qobuz_1.2.12-1_all.deb
Length: 14824 (14K) [application/octet-stream]
Saving to: 'upmpdcli-qobuz_1.2.12-1_all.deb'
upmpdcli-qobuz_1.2.12-1_all.deb 100%[============================================================>] 14.48K --.-KB/s in 0.03s
2017-03-17 04:17:57 (546 KB/s) - 'upmpdcli-qobuz_1.2.12-1_all.deb' saved [14824/14824]
converted 'http://repo.volumio.org/Packages/Upmpdcli/upmpdcli-tidal_1.2.12-1_all.deb' (ANSI_X3.4-1968) -> 'http://repo.volumio.org/Packages/Upmpdcli/upmpdcli-tidal_1.2.12-1_all.deb' (UTF-8)
--2017-03-17 04:17:57-- http://repo.volumio.org/Packages/Upmpdcli/upmpdcli-tidal_1.2.12-1_all.deb
Length: 11470 (11K) [application/octet-stream]
Saving to: 'upmpdcli-tidal_1.2.12-1_all.deb'
upmpdcli-tidal_1.2.12-1_all.deb 100%[============================================================>] 11.20K --.-KB/s in 0.05s
2017-03-17 04:17:58 (215 KB/s) - 'upmpdcli-tidal_1.2.12-1_all.deb' saved [11470/11470]
Selecting previously unselected package upmpdcli-gmusic.
(Reading database ... 31024 files and directories currently installed.)
Preparing to unpack upmpdcli-gmusic_1.2.12-1_all.deb ...
Unpacking upmpdcli-gmusic (1.2.12-1) ...
Setting up upmpdcli-gmusic (1.2.12-1) ...
Selecting previously unselected package upmpdcli-qobuz.
(Reading database ... 31030 files and directories currently installed.)
Preparing to unpack upmpdcli-qobuz_1.2.12-1_all.deb ...
Unpacking upmpdcli-qobuz (1.2.12-1) ...
Setting up upmpdcli-qobuz (1.2.12-1) ...
Selecting previously unselected package upmpdcli-tidal.
(Reading database ... 31043 files and directories currently installed.)
Preparing to unpack upmpdcli-tidal_1.2.12-1_all.deb ...
Unpacking upmpdcli-tidal (1.2.12-1) ...
Setting up upmpdcli-tidal (1.2.12-1) ...
Creating Volumio Folder Structure
mkdir: cannot create directory '/media': File exists
Prepping MPD environment
Setting mpc to bind to unix socket
Setting Permissions for /etc/modules
Adding Volumio Parent Service to Startup
Adding Volumio Remote Updater Service to Startup
Adding Udisks-glue service to Startup
Adding First start script
Adding Dynamic Swap Service
Setting Mpd to SystemD instead of Init
Synchronizing state for mpd.service with sysvinit using update-rc.d...
Executing /usr/sbin/update-rc.d mpd defaults
Executing /usr/sbin/update-rc.d mpd enable
Preventing un-needed dhcp servers to start automatically
Synchronizing state for isc-dhcp-server.service with sysvinit using update-rc.d...
Executing /usr/sbin/update-rc.d isc-dhcp-server defaults
Executing /usr/sbin/update-rc.d isc-dhcp-server disable
insserv: warning: current start runlevel(s) (empty) of script `isc-dhcp-server' overrides LSB defaults (2 3 4 5).
insserv: warning: current stop runlevel(s) (0 1 2 3 4 5 6) of script `isc-dhcp-server' overrides LSB defaults (0 1 6).
Adding Users to Audio Group
Setting RT Priority to Audio Group
Alsa tuning
Creating Alsa state file
Tuning LAN
Disabling IPV6
#disable ipv6
net.ipv6.conf.all.disable_ipv6 = 1
net.ipv6.conf.default.disable_ipv6 = 1
net.ipv6.conf.lo.disable_ipv6 = 1
Wireless
Configuring hostapd
Hostapd conf files
Setting fallback DNS with Google's DNS
Removing Avahi Service for UDISK-SSH
Creating DHCPCD folder structure
mkdir: cannot create directory '/var/lib/dhcpcd5': File exists
Base System Installed
Writing system information
Unmounting Temp devices
umount: build/x86/root/dev: must be superuser to unmount
umount: build/x86/root/proc: must be superuser to unmount
umount: build/x86/root/sys: must be superuser to unmount
umount: build/x86/root/run/cgmanager/fs: must be superuser to unmount
Copying Custom Volumio System Files
Copying X86 related Configuration files
cp: cannot create regular file 'build/x86/root/volumio/app/plugins/system_controller/network/wireless.js': No such file or directory
Done Copying Custom Volumio System Files
Stripping binaries and libraries to save space
Writing x86 Image File
Creating Image Bed
Image file: Volumio2.0-2017-03-17-x86.img
3900+0 records in
3900+0 records out
4089446400 bytes (4.1 GB) copied, 17.3554 s, 236 MB/s
losetup: cannot find an unused loop device
Error: Could not stat device - No such file or directory.
/dev/mapper/control: open failed: Operation not permitted
Failure to communicate with kernel device-mapper driver.
Check that device-mapper is available in the kernel.
Incompatible libdevmapper � and kernel driver
device mapper prerequisites not met
/dev/mapper/p1 doesn't exist
