Hello all! Volumio newbie here
Hopefully, I 'm in the right section. Although I appreciate the fact that Volumio users utilise mostly Raspberry Pi and similar SBCs, I 'm thinking to build my Volumio using x86 components and add to my existing rack.
In order to do so I 'd like to use a PCIe sound card probably in the form of an Asus Xonar Essence STX as the DAC instead of the onboard HDMI. I know that this card is supported in Linux, but would it work with Volumio?
Appreciate any feedback. Thanks!
