After a factory reset (or after burning a fresh copy), I select “Hifiberry DAC Plus” (I have a Hifiberry Amp 2) and go through the rest of the setup. After finishing I select e.g. an Internet Radio station and all is fine.
When I go to the settings Menu, it shows “IQaudiO DAC Plus”, and not the Hifiberry that I selected.
Then I perform a reboot, and after hitting the “Play” button I get “Failed to Open ALSA …”. The only way to recover is another factory reset. Re-selecting the Hifiberry does not work.
This started a few releases back (I don’t remember which one) and persists today with 2.565.
After the next reset I’ll try to use English (my tests were done with German) to see if this makes any difference.
What could be wrong here?
Update: With English the above problem does not happen. In return, the Internet Radio “Browse” section is broken. For example, no radio station is ever found when I search.
Sorry, update to the update: It’s not the language. After yet another factory reset I selected “German” again, and did not see the problem with the DAC. Search doesn’t work either in German. I have no idea what’s going on…
