write error - volumio network disk mount
I can’t copy (write) files into Volumio network mount.
I’m on Mac Os X Mavericks.
It’s connected as Root or Volumio.
Error message: “The operation can’t be completed because an unexpected error occurred (error code -50).”
I can rename and delete files without any problems.
Do you have the chance to use other O.S.?
I will try it on Windows 7
Max OS X is my main OS though.
suddenly it’s working standard english titles! :slight_smile:
but it doesn’t work with foreign characters!
I cannot copy or create any folders with “ą ę ć” etc.
It seems then you have the same problem than me…
utf-8-support-t163.html
