RPI3 - did check internet connection - am i missing something - or is it a bug?
I’m noticing the same, working to fix this…
I’d like to just post that I have the same issue from 2.029. Won’t update to 2.030 as it says that I have the latest version.
Ok I saw another solution that worked which is to go to volumio.local/dev and set Test Mode to True and try the update again.
Thanks.
Guys, now the updater works well.
We just had a problem a couple of days last weekend, which I found and fixed
