Wolfson: drivers near to ber pulled in the official kernel
Hi guys!
It seems that Wolfson audio card driver will be pulled soon into the mainline rpi kernel :slight_smile:
github.com/raspberrypi/linux/pull/705/files
I’m tryng to compile 3.12.y starting from the pull request author repository:
github.com/manish-wolfsonmicro/linux
right now with the .config generated from my volumio 1.5 with old - but working - kernel 3.12.13.
I’ll let you know the results asap!!
Bye bye
Hey there m3m3nto.
These r indeed good news! :slight_smile: I guess I will just wait until the Wolfson drivers r part of the rpi kernel. I downloaded your 1.5-Wolfson image yesterday but no sound comes out of the wolfson card - the onboard soundcard works fine, though.
Crossing my fingers that everything gets integrated quickly. :smiley:
Thanks for your hard work!
Best.
bearmann
Hi bearman!
Thank you for your message.
Sorry!!! I noticed only now that in the confix.txt in not present the line:
kernel=kernel_new.img
So, mount the sd card and edit the file confix.txt in the boot partition:
kernel=kernel_new.img gpu_mem=16 hdmi_drive=2
To switch between wolfson output use the script located into /home/pi/wolfson_drivers
Access to rpi via ssh then
cd /home/pi/wolfson_drivers
headset output:
sudo ./Playback_to_Headset.sh
Let me know if this solution works for you!
Bye bye!
