I used current Volumio (3.631) on a Raspi3 for some months using LAN for network access. Now I wanted to change that and use WLAN instead. Unfortunately, it doesn’t connect to my WLAN network (translated from german to english):
- Settings → Network: State: empty
- Cable: Automatic IP: on
- WLAN: on, automatic IP: on
My networks are listed correctly and if I activate the hotspot option I can connect to the Raspi. But if I select my WLAN network (password is there) and select Connect:
- a message is shown like: WLAN network restarted…, after some seconds the network settings windows is refreshed, but networking state stays empty.
What can be the reason and what can I do to find out what’s happening here?
Thank you.
Bernd
