Ping to Pi B+ connected via Wlan looks like a swiss cheese, once Hifiberry Digi+ is installed.
Volumio 1.55
Pi Model B+
Hifiberry Digi+/Digi+ (Transf. Version)
Wlan Edimax EW-7811Un
Music Fidelity V90-DAC
The setup works like a charm, when I do not install the Hifiberry Digi+ on the Pi and ping the Pi via WLAN. Wlan works smoothly and stable.
But once I install the Hifiberry on the Pi board, the Pi is not always pingable - it looks very strange instead, like this:
C:\voo>ping 192.168.1.3 -t
Ping wird ausgeführt für 192.168.1.3 mit 32 Bytes Daten:
Zeitüberschreitung der Anforderung.
Antwort von 192.168.1.10: Zielhost nicht erreichbar.
Antwort von 192.168.1.3: Bytes=32 Zeit=1798ms TTL=64
Antwort von 192.168.1.3: Bytes=32 Zeit=7ms TTL=64
Antwort von 192.168.1.3: Bytes=32 Zeit=8ms TTL=64
Antwort von 192.168.1.3: Bytes=32 Zeit=237ms TTL=64
Antwort von 192.168.1.3: Bytes=32 Zeit=6ms TTL=64
Antwort von 192.168.1.3: Bytes=32 Zeit=10ms TTL=64
Did anyone experience such problems? I even tried two Hifiberry Digi+ boards (Transformer Version/ non-Transformer-Version). Same effect. The Digi+ seems to disturb the Pi’s WLAN for some reason. The strange thing: the setup was working for a few days at the beginning.
