I am running Volume 1.51 on raspberry B+ and I tried to install wiringPi library.
I did a sudo apt-get followed by sudo apt-upgrade
and then tried to install wiringPi.
It failed with a segmentation fault
I then tried it with Volume 1.51 and a normal raspberry B
This time I did not upgrade the system and tried to install wiringPi directly
It failed with the error message that it can’t find the command gcc
I check with apt-get install and gcc is installed and up to date.
Any help?
Where is gcc installed (folder)?
Is it a good idea to run apt-get upgrade on Volumio?
