Wireless Adapter Compatibility List
Please note this is not a general Volumio topic, wireless support is mostly platform and kernel version specific.
A device working with PI does not necessarily work with x86 or tinkerboard.
TP-Link T3U (rtl8812bu) will work on x86 for images built after 15.01.22 (release version > 3.179)
Hi, can anybody help me? I got a cheap china passive cooled Nuc like x64 Hardware with a installed m.2 wifi card that can connect to a hotspot but can’t open a hotspot.
Can anybody recommend a chipset, that can do both? Or can recommend a card that can do that?
Sorry for my terrible english :wink:
thx
Hi!
Which wifi card do you recommend for Usbridge Sig.? So that it works without drivers? I have TP-LINK TL-WN722N and it drops the connection on the new Volumio. At 2.917 it’s ok.
Hi
New kernel broke a lot of Wifi dongles. Was documented in a thread, but for remplacement, have a look at https://community.volumio.com/t/wireless-driver-compatibility-list-renewed-for-volumio-3-kernel-5-10/54754/5
Regards
Thanks!
Adapter Name: TP-Link AC1300 Mini Wifi MU-MIMO USB 3.0-adapter
Chipset: Realtek rtl8812bu
Driver/Firmware: …/…/…/…/…/…/bus/usb/drivers/rtl88x2bu
Working with Volumio: Working with V3.378
Tested Versions and Platforms: X86
Comments: needed to perform a factory reset, most likely caused by me, messing around with the system/settings, as this is a development unit.
Buying Link: https://www.amazon.nl/gp/product/B07M69276N
Has anyone managed to get a TPLink AC600 T2U Plus working with Volumio 3.198+?
It works with all version less than 3.198, it needs RTL 8192 support. I need a super strong wifi dongle, the edimax i have dosnt cut it.
Running 3.197 and the T2U plus is so powerful, but im stuck on the old Volumio version :frowning:
Please help! - thanks
please do not cross-post
