I’m a MacOS guy and have been using Volumio for years. I’m now trying to help a friend set it up (I’m connecting remotely into his Windows 10 machine using Team Viewer. The RPi is up and running and I can connect to the RPi’s webUI, but I can’t get the drive to mount and would appreciate some guidance.
This is what I’ve tried
IP Address: 192.168.1.3
Path: Chris/Music/EAC this is a folder on his PC’s HD where Chris is his user area/name
Share Type: gifs
Username: Chris
Password: what he tells me it is
Options: ro,noatime,sec=ntlmv2
Is there anything obviously wrong with this? I know the path would be correct for a Mac, but maybe it’s not correct a PC. Should it be C:\Users\CHRIS\Music|EAC? Back slashes or forward slashes?
Indeed backslashes but also you need to specify the cifs version of at least 2.1 if a recall correctly (so add vers=2.1 into the comma seperated list of options).
