This post is a follow up to https://volumio.org/forum/send-log-bug-report-fails-t10926.html
As I indicated there, I’m trying to resolve some problems I’m having with my Allo Boss Player running Volumio 2.457 and connecting to a network via a TP-Link TL-WN822N. Since Chsims1 kindly told me how to use sudo journalctl via SSH, I’ve been looking at the various warnings there and trying to figure them out. I resolved the network problems I mentioned in the previous thread: the gateway ip was incorrect and it took me an embarrassing amount of time to figure that out, starting with a fresh install that erased the static ip and suddenly was working correctly and re-setting up the static ip worked fine and the player seems to work great.
However, there are still some apparent error messages in the boot logs that I’d like to correct or at least understand better. During the boot, the following messages appear in lines 554-659 of the boot log, consisting primarily of “no such file or directory messages”
Nov 03 11:10:46 volumio winbind[598]: Starting the Winbind daemon: winbindmkdir failed on directory /var/log/samba/cores: No such file or directory
Nov 03 11:10:46 volumio winbind[598]: Failed to create /var/log/samba/cores for user 0 with mode 0700
Nov 03 11:10:46 volumio winbind[598]: Unable to setup corepath for winbindd: No such file or directory
Nov 03 11:10:46 volumio winbind[598]: mkdir failed on directory /var/log/samba/cores: No such file or directory
Nov 03 11:10:46 volumio winbind[598]: [2018/11/03 11:10:46, 0] ../lib/util/debug.c:603(reopen_logs_internal)
Nov 03 11:10:46 volumio winbind[598]: Unable to open new log file '/var/log/samba/log.winbindd': No such file or directory
Nov 03 11:10:46 volumio winbind[598]: [2018/11/03 11:10:46, 0] ../source3/winbindd/winbindd.c:1549(main)
Nov 03 11:10:46 volumio winbind[598]: winbindd version 4.2.14-Debian started.
Nov 03 11:10:46 volumio winbind[598]: Copyright Andrew Tridgell and the Samba Team 1992-2014
Nov 03 11:10:46 volumio winbind[598]: [2018/11/03 11:10:46, 0] ../lib/util/util.c:220(directory_create_or_exist)
Nov 03 11:10:46 volumio winbind[598]: [2018/11/03 11:10:46, 0] ../source3/lib/dumpcore.c:59(get_default_corepath)
Nov 03 11:10:46 volumio winbind[598]: [2018/11/03 11:10:46, 0] ../source3/lib/dumpcore.c:250(dump_core_setup)
Nov 03 11:10:46 volumio winbindd[787]: [2018/11/03 11:10:46.300212, 0] ../lib/util/debug.c:603(reopen_logs_internal)
Nov 03 11:10:46 volumio winbindd[787]: Unable to open new log file '/var/log/samba/log.winbindd': No such file or directory
Nov 03 11:10:46 volumio winbindd[787]: [2018/11/03 11:10:46.301262, 0] ../lib/util/debug.c:603(reopen_logs_internal)
Nov 03 11:10:46 volumio winbind[598]: [2018/11/03 11:10:46.300212, 0] ../lib/util/debug.c:603(reopen_logs_internal)
Nov 03 11:10:46 volumio winbind[598]: [2018/11/03 11:10:46.301262, 0] ../lib/util/debug.c:603(reopen_logs_internal)
Nov 03 11:10:46 volumio nmbd[602]: Starting NetBIOS name server: nmbdmkdir failed on directory /var/log/samba/cores: No such file or directory
Nov 03 11:10:46 volumio nmbd[602]: Failed to create /var/log/samba/cores for user 0 with mode 0700
Nov 03 11:10:46 volumio nmbd[602]: Unable to setup corepath for nmbd: No such file or directory
Nov 03 11:10:46 volumio nmbd[804]: [2018/11/03 11:10:46.316212, 0] ../lib/util/debug.c:603(reopen_logs_internal)
Nov 03 11:10:46 volumio nmbd[804]: Unable to open new log file '/var/log/samba/log.nmbd': No such file or directory
Nov 03 11:10:46 volumio nmbd[804]: [2018/11/03 11:10:46.317603, 0] ../lib/util/debug.c:603(reopen_logs_internal)
Nov 03 11:10:46 volumio nmbd[602]: [2018/11/03 11:10:46, 0] ../lib/util/debug.c:603(reopen_logs_internal)
Nov 03 11:10:46 volumio nmbd[602]: Unable to open new log file '/var/log/samba/log.nmbd': No such file or directory
Nov 03 11:10:46 volumio nmbd[602]: [2018/11/03 11:10:46, 0] ../source3/nmbd/nmbd.c:908(main)
Nov 03 11:10:46 volumio nmbd[602]: nmbd version 4.2.14-Debian started.
Nov 03 11:10:46 volumio nmbd[602]: Copyright Andrew Tridgell and the Samba Team 1992-2014
Nov 03 11:10:46 volumio nmbd[602]: [2018/11/03 11:10:46.316212, 0] ../lib/util/debug.c:603(reopen_logs_internal)
Nov 03 11:10:46 volumio nmbd[602]: [2018/11/03 11:10:46.317603, 0] ../lib/util/debug.c:603(reopen_logs_internal)
Nov 03 11:10:46 volumio nmbd[805]: [2018/11/03 11:10:46.320812, 0] ../source3/nmbd/asyncdns.c:157(start_async_dns)
Nov 03 11:10:46 volumio nmbd[805]: started asyncdns process 806
Nov 03 11:10:46 volumio systemd[1]: Started LSB: start Samba NetBIOS nameserver (nmbd).
Nov 03 11:10:46 volumio systemd[1]: Starting LSB: start Samba SMB/CIFS daemon (smbd)...
Nov 03 11:10:46 volumio nmbd[602]: .
Nov 03 11:10:47 volumio smbd[807]: Starting SMB/CIFS daemon: smbd[2018/11/03 11:10:47, 0] ../lib/util/debug.c:603(reopen_logs_internal)
Nov 03 11:10:47 volumio smbd[807]: Unable to open new log file '/var/log/samba/log.smbd': No such file or directory
Nov 03 11:10:47 volumio smbd[807]: [2018/11/03 11:10:47, 0] ../lib/util/util.c:220(directory_create_or_exist)
Nov 03 11:10:47 volumio smbd[807]: mkdir failed on directory /var/log/samba/cores: No such file or directory
Nov 03 11:10:47 volumio smbd[807]: [2018/11/03 11:10:47, 0] ../source3/lib/dumpcore.c:59(get_default_corepath)
Nov 03 11:10:47 volumio smbd[807]: Failed to create /var/log/samba/cores for user 0 with mode 0700
Nov 03 11:10:47 volumio smbd[807]: [2018/11/03 11:10:47, 0] ../source3/lib/dumpcore.c:250(dump_core_setup)
Nov 03 11:10:47 volumio smbd[807]: Unable to setup corepath for smbd: No such file or directory
Nov 03 11:10:47 volumio smbd[807]: [2018/11/03 11:10:47, 0] ../lib/util/debug.c:603(reopen_logs_internal)
Nov 03 11:10:47 volumio smbd[807]: [2018/11/03 11:10:47, 0] ../source3/smbd/server.c:1241(main)
Nov 03 11:10:47 volumio smbd[807]: smbd version 4.2.14-Debian started.
Nov 03 11:10:47 volumio smbd[807]: Copyright Andrew Tridgell and the Samba Team 1992-2014
Nov 03 11:10:47 volumio smbd[816]: [2018/11/03 11:10:47.375376, 0] ../lib/util/debug.c:603(reopen_logs_internal)
Nov 03 11:10:47 volumio smbd[816]: Unable to open new log file '/var/log/samba/log.smbd': No such file or directory
Nov 03 11:10:47 volumio smbd[816]: [2018/11/03 11:10:47.376745, 0] ../lib/util/debug.c:603(reopen_logs_internal)
Nov 03 11:10:47 volumio smbd[816]: [2018/11/03 11:10:47.376879, 0] ../lib/util/debug.c:603(reopen_logs_internal)
Nov 03 11:10:47 volumio smbd[807]: [2018/11/03 11:10:47.375376, 0] ../lib/util/debug.c:603(reopen_logs_internal)
Nov 03 11:10:47 volumio smbd[807]: [2018/11/03 11:10:47.376745, 0] ../lib/util/debug.c:603(reopen_logs_internal)
Nov 03 11:10:47 volumio smbd[807]: [2018/11/03 11:10:47.376879, 0] ../lib/util/debug.c:603(reopen_logs_internal)
Nov 03 11:10:47 volumio sudo[797]: pam_unix(sudo:session): session closed for user root
Nov 03 11:10:47 volumio kernel: RTL871X: nolinked power save leave
Nov 03 11:10:47 volumio nmbd[805]: [2018/11/03 11:10:47.589721, 0] ../lib/util/become_daemon.c:135(daemon_status)
Nov 03 11:10:47 volumio nmbd[805]: STATUS=daemon 'nmbd' : No local IPv4 non-loopback interfaces available, waiting for interface ...NOTE: NetBIOS name resolu
Nov 03 11:10:47 volumio winbindd[822]: [2018/11/03 11:10:47.610482, 0] ../source3/winbindd/winbindd_cache.c:3235(initialize_winbindd_cache)
Nov 03 11:10:47 volumio winbindd[822]: initialize_winbindd_cache: clearing cache and re-creating with version number 2
Nov 03 11:10:47 volumio winbind[598]: .
Nov 03 11:10:47 volumio systemd[1]: Started LSB: start Winbind daemon.
Nov 03 11:10:47 volumio smbd[807]: .
Nov 03 11:10:47 volumio systemd[1]: Started LSB: start Samba SMB/CIFS daemon (smbd).
Nov 03 11:10:47 volumio winbindd[822]: [2018/11/03 11:10:47.650216, 0] ../lib/util/become_daemon.c:124(daemon_ready)
Nov 03 11:10:47 volumio winbindd[822]: STATUS=daemon 'winbindd' finished starting up and ready to serve connections
Nov 03 11:10:47 volumio winbindd[825]: [2018/11/03 11:10:47.654431, 0] ../lib/util/debug.c:603(reopen_logs_internal)
Nov 03 11:10:47 volumio winbindd[825]: Unable to open new log file '/var/log/samba/log.wb-VOLUMIO': No such file or directory
Nov 03 11:10:47 volumio wireless.js[731]: Stopped aP
Nov 03 11:10:47 volumio wireless.js[731]: Start wireless flow
Nov 03 11:10:47 volumio wireless.js[731]: Stopped hotspot (if there)..
Nov 03 11:10:47 volumio sudo[830]: root : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/ip addr flush dev wlan0
Nov 03 11:10:47 volumio sudo[830]: pam_unix(sudo:session): session opened for user root by (uid=0)
Nov 03 11:10:47 volumio sudo[830]: pam_unix(sudo:session): session closed for user root
Nov 03 11:10:47 volumio winbindd[836]: [2018/11/03 11:10:47.733085, 0] ../lib/util/debug.c:603(reopen_logs_internal)
Nov 03 11:10:47 volumio winbindd[836]: Unable to open new log file '/var/log/samba/log.wb-BUILTIN': No such file or directory
Nov 03 11:10:47 volumio winbindd[840]: [2018/11/03 11:10:47.747155, 0] ../lib/util/debug.c:603(reopen_logs_internal)
Nov 03 11:10:47 volumio winbindd[840]: Unable to open new log file '/var/log/samba/log.winbindd-idmap': No such file or directory
Nov 03 11:10:47 volumio sudo[839]: root : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/ifconfig wlan0 down
Nov 03 11:10:47 volumio sudo[839]: pam_unix(sudo:session): session opened for user root by (uid=0)
Nov 03 11:10:47 volumio sudo[839]: pam_unix(sudo:session): session closed for user root
Nov 03 11:10:47 volumio smbd[821]: [2018/11/03 11:10:47.775880, 0] ../lib/util/become_daemon.c:124(daemon_ready)
Nov 03 11:10:47 volumio smbd[821]: STATUS=daemon 'smbd' finished starting up and ready to serve connections
Nov 03 11:10:47 volumio smbd[848]: [2018/11/03 11:10:47.780485, 0] ../lib/util/debug.c:603(reopen_logs_internal)
Nov 03 11:10:47 volumio smbd[848]: Unable to open new log file '/var/log/samba/log.smbd': No such file or directory
After the boot completes, the following messages appear periodically (every 28 minutes):
Nov 03 11:14:06 volumio smbd[3118]: [2018/11/03 11:14:06.085504, 0] ../lib/util/debug.c:603(reopen_logs_internal)
Nov 03 11:14:06 volumio smbd[3118]: Unable to open new log file '/var/log/samba/log.smbd': No such file or directory
Nov 03 11:14:06 volumio smbd[3118]: [2018/11/03 11:14:06.104981, 0] ../lib/util/debug.c:603(reopen_logs_internal)
Nov 03 11:14:06 volumio smbd[3118]: [2018/11/03 11:14:06.105283, 0] ../lib/util/debug.c:603(reopen_logs_internal)
Nov 03 11:14:06 volumio smbd[3118]: [2018/11/03 11:14:06.105551, 0] ../lib/util/debug.c:603(reopen_logs_internal)
Nov 03 11:14:06 volumio smbd[3118]: [2018/11/03 11:14:06.122576, 0] ../lib/util/debug.c:603(reopen_logs_internal)
Nov 03 11:14:06 volumio smbd[3118]: [2018/11/03 11:14:06.132999, 0] ../lib/util/debug.c:603(reopen_logs_internal)
Meanwhile, the player seems to be working properly.
