Have noticed the following behavior: If my router goes down, volumio does not reconnect again when it’s up again. Works fine for wired connections but not wifi.
You have to reboot to get “on-line”.
Sent from my iPhone using Tapatalk
You might like to try the following plugin github.com/balbuze/volumio-plug … ireconnect
Thanks for the tip. Tried to install it but no result. Nothing was added to /data/plugins
Do you mean you can’t install or you can install but don’t solve your problem ?
It looks like it installs but no folder structure is created under /data/plugins/
