I can get volumio working on Ethernet but when I try wifi it doesn’t work. I enter the ssid and password then unplug the Ethernet and just get the word connecting with circling arrows on the screen. The wifi adapter has a blinking light so it’s trying but just doesn’t connect. What am I doing wrong . Thanks.
Do you used the second save button on the bottom page in wifi settings?I
You have to wait two minutes, then shut down and reboot the sistem without ethernet plugged on.
Inviato dal mio SM-N9005 utilizzando Tapatalk
