I have two rpi based systems. One is the rpi2 with HiFiberry Amp+ running Volumio 1.55. The other is a rpiB+ with a HiFiberry DAC running Raspian.
Whenever I must reboot the WiFi router the Raspbian rpi auto reconnect to the wifi network. However, with the Volumio rpi2 I must reboot the rpi2 in order to reconnect to the WiFi network were the rpi running Raspian does it automatically with out rebooingt the rpi.
Is there a setting thru the web interface or command line for setting up Volumio to auto reconnect on a WiFi router recboot - reconnect ?
My router turn the Wifi down at night (no signal) and it’s running for months im not having any problem.
So either this is a limited setup issue or my wifi doesn’t turn down… Will check that later.
