Hei,
Does anyone know how I can get volumio working with the Netgear 150 wireless USB adaptor ?
I plugged it in, configured it in the web gui but it does not appear to connect. The web gui shows now IP address on the wlan0 interface and if I unplug the cable I cannot access the PI.
There does not appear to be any error message anywhere that I have managed to find (I am not an expert PI user).
If I ssh into the PI and run dmesg I can see:
usb 1-1.2: new high-speed USB device number 4 using dwc_otg
usb 1-1.2: New USB device found, idVendor=0846, idProduct=9041
usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
usb 1-1.2: Product: 802.11n WLAN Adapter
usb 1-1.2: Manufacturer: Realtek
usb 1-1.2: SerialNumber: 00e04c000001
So it appears to be detecting the adapter.
If I run “ip link show” :
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN mode DEFAULT
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP mode DEFAULT qlen 1000
link/ether b8:27:eb:e8:e5:16 brd ff:ff:ff:ff:ff:ff
I cannot see the wlan0, so I think there is a problem somewhere … but where.
I have looked at the automatic script written by MrEngman, but when I run it I get:
"An RTL8188CUS driver module is installed but is not loaded.
You have 1 wifi adapter configured.
wlan0 is configured but is not installed.
The Pi has an internet connection.
Any files needed for the installation/upgrade will be downloaded from the
Internet unless they have already been copied to the SD card /boot directory.
Unrecognised software version: Linux volumio 3.8.10+ #1 PREEMPT Mon Oct 21 10:36:33 CEST 2013 armv6l GNU/Linux
Downloading the latest script.
The script you’re using is the latest version.
Aborting the rtl8188cus installation script."
Reading around a bit, it appears that the script should no longer be needed since the correct drivers should be included in the base image.
Anyone have an idea why it is not working, or any help in investigating how to get it working ?
Ian
