Wifi adapter help for Raspberry Pi b+
I just found out about Volumio through a podcast and I had some questions. I installed the software onto my Raspberry Pi B+ the other day and it worked fine on an Ethernet connection, but I need to use it on wifi. I bought a wifi adapter that is compatible with volumio but how do I go about downloading the drivers, as it didn’t work out of the box.
It is a TP-LINK TL-WN725N.
Thank you so much!
~Riley
Please have look here https://volumio.org/forum/wireless-adapter-compatibility-list-t2150.html your adaptater
will work by following : https://www.raspberrypi.org/forums/viewtopic.php?p=462982#p462982 :smiley:
choose the version adapted for your kernel sudo uname -a :wink:
