I use the lastest git clone source for volumio , but when visit the web ui from 3000 port use chrome or firefox , the browser report the :
ERR_TOO_MANY_REDIRECTS error , have any suggest for this :
2016-01-19T09:34:07.402Z - info: -------------------------------------------
2016-01-19T09:34:07.421Z - info: ----- Volumio2 ----
2016-01-19T09:34:07.421Z - info: -------------------------------------------
2016-01-19T09:34:07.422Z - info: ----- System startup ----
2016-01-19T09:34:07.422Z - info: -------------------------------------------
2016-01-19T09:34:07.578Z - info: Loading plugins from folder /adaplayer/app/plugins/
2016-01-19T09:34:07.644Z - info: Loading plugins from folder /data/plugins/
2016-01-19T09:34:07.645Z - info: Loading plugin “system”…
2016-01-19T09:34:07.689Z - info: Loading plugin “network”…
2016-01-19T09:34:07.973Z - info: Loading plugin “networkfs”…
2016-01-19T09:34:08.001Z - info: Loading plugin “services”…
2016-01-19T09:34:08.007Z - info: Loading plugin “volumiodiscovery”…
2016-01-19T09:34:08.962Z - info: Started advertising…
2016-01-19T09:34:08.973Z - info: Loading plugin “alsa_controller”…
2016-01-19T09:34:09.055Z - info: Loading plugin “upnp”…
2016-01-19T09:34:09.813Z - info: [1453196049812] Starting Upmpd Daemon
2016-01-19T09:34:09.868Z - info: Loading plugin “alarm-clock”…
2016-01-19T09:34:10.299Z - info: Loading plugin “albumart”…
2016-01-19T09:34:10.316Z - info: Loading plugin “airplay_emulation”…
2016-01-19T09:34:10.328Z - info: [1453196050327] Starting Shairport Sync
2016-01-19T09:34:10.330Z - info: Loading plugin “dirble”…
2016-01-19T09:34:10.969Z - info: Plugin example_plugin is not enabled
2016-01-19T09:34:10.969Z - info: Loading plugin “mpd”…
2016-01-19T09:34:11.755Z - info: Loading plugin “spop”…
2016-01-19T09:34:11.779Z - info: [1453196051779] ControllerSpop::loadTracklistFromDB
2016-01-19T09:34:11.780Z - info: Loading Spop tracklist from DB…
2016-01-19T09:34:11.785Z - info: Loading plugin “updater_comm”…
2016-01-19T09:34:12.942Z - info: Plugin mpdemulation is not enabled
2016-01-19T09:34:12.942Z - info: Loading plugin “websocket”…
2016-01-19T09:34:14.239Z - info: BOOT COMPLETED
2016-01-19T09:34:14.248Z - info: [1453196054248] CoreStateMachine::resetVolumioState
2016-01-19T09:34:14.249Z - info: [1453196054249] CoreStateMachine::getcurrentVolume
2016-01-19T09:34:14.249Z - info: CoreCommandRouter::volumioRetrievevolume
2016-01-19T09:34:14.271Z - info: [1453196054271] CoreStateMachine::updateTrackBlock
2016-01-19T09:34:14.272Z - info: [1453196054271] CorePlayQueue::getTrackBlock
2016-01-19T09:34:14.310Z - info: SpopD Daemon Started
2016-01-19T09:34:14.315Z - info: MPD running with PID646 ,establishing connection
2016-01-19T09:34:14.450Z - info: [1453196054450] ControllerSpop::pushError(Error: Error reading DB: NotFoundError: Key not found in database [tracklist])
2016-01-19T09:34:14.493Z - info: Setting volume on startup at 50
2016-01-19T09:34:14.496Z - info: [1453196054496] VolumeController:: Volume=51 Mute =false
2016-01-19T09:34:14.498Z - info: [1453196054498] CoreStateMachine::updateVolume10
2016-01-19T09:34:14.499Z - info: [1453196054499] CoreStateMachine::getState
2016-01-19T09:34:14.500Z - info: [1453196054499] CoreStateMachine::pushState
2016-01-19T09:34:14.500Z - info: CoreCommandRouter::volumioPushState
2016-01-19T09:34:14.500Z - info: [1453196054500] InterfaceWebUI::pushState
2016-01-19T09:34:14.507Z - info: CoreCommandRouter::volumioClearQueue
2016-01-19T09:34:14.508Z - info: [1453196054508] CoreStateMachine::ClearQueue
2016-01-19T09:34:14.508Z - info: [1453196054508] CorePlayQueue::clearPlayQueue
2016-01-19T09:34:14.521Z - info:
[1453196054520] ---------------------------- Client requests Volume 50
2016-01-19T09:34:14.522Z - info: [1453196054522] VolumeController::SetAlsaVolume50
2016-01-19T09:34:14.527Z - info: [1453196054527] ------------------------------ 7ms
2016-01-19T09:34:14.539Z - info: CoreCommandRouter::volumioAddQueueItems
2016-01-19T09:34:14.540Z - info: [1453196054540] CoreStateMachine::addQueueItems
2016-01-19T09:34:14.541Z - info: [1453196054541] CorePlayQueue::addQueueItems
2016-01-19T09:34:14.542Z - info: CoreCommandRouter::volumioPushQueue
2016-01-19T09:34:14.542Z - info: [1453196054542] InterfaceWebUI::pushQueue
2016-01-19T09:34:14.544Z - info: mDNS: Found device ADAplayer
2016-01-19T09:34:14.549Z - info: [1453196054549] VolumeController::Volume 50
2016-01-19T09:34:14.549Z - info: [1453196054549] CoreStateMachine::updateVolume50
2016-01-19T09:34:14.550Z - info: [1453196054550] CoreStateMachine::getState
2016-01-19T09:34:14.552Z - info: [1453196054551] CoreStateMachine::pushState
2016-01-19T09:34:14.553Z - info: CoreCommandRouter::volumioPushState
2016-01-19T09:34:14.553Z - info: [1453196054553] InterfaceWebUI::pushState
2016-01-19T09:34:14.559Z - info: mDNS: Found device ADAplayer
2016-01-19T09:34:14.684Z - info: [1453196054683] Shairport-sync error: Error: Command failed: /bin/sh -c sudo systemctl restart airplay
Failed to restart airplay.service: Unit airplay.service failed to load: No such file or directory.
